I'm not sure if this is the right term. however, here goes.
If I put a dial indicator in my mill spindle, and traverse the table from front to back, i see a drop of about 0.12 mm. If I traverse it left to right then it's pretty much spot on.
I'm open to being wrong on this, but I don't think that this is about head tramming, as the head isn't moving. Instead I theorise that the table is effectively at an angle with respect to the base.
That is, that the back of the table is just a tad higher than the front.
I expect I can sort this by shimming up my work, and am experimenting with this to see if I can get a (nearly) perfectly flat surface.
I would expect that the proper fix is most likely to be to reduce the back X jib (the surface on which the table sits, if I have the name wrong). I guess this would need to go down by some 0.08 mm (I've not done the maths).
How would I do this? Ideally, an approach that suits my limited equipment (clearly, I can't use the mill…) and even more limited skills.
Thanks
Iain
