I've remained true to Antex Irons since I was 14. They're British, with replaceable tips. The versions fitted with Silicone Rubber cables are best, because they're heatproof and more flexible.
Tips last much longer if the iron is holstered in a spiral spring stand with a damp sponge so acid flux muck can be wiped off immediately. Tips are copper plated iron, disposable, and not worth filing.
My irons are all from the 'Precision Range' and I own three, all good at particular jobs:
- A 12W Iron with a fine tip is used for delicate electronics – miniature components
- A 15W Iron with a larger tip is used for ordinary transistor sized electronics
- A 25W Iron with a big tip (small by plumber standards), is for vacuum valve sized electronics
Of these the 15W and 25W irons can both do solder tags, but I prefer the 25W because the extra heat solders faster and reduces the risk of a bad joint. The extra heat is particularly useful when a wire is soldered to a tag already bolted to a chassis, because the chassis conducts heat rapidly away from the joint.
I notice Antex sell an 18W iron, which might be just the right power for Lynne's requirement.
I've owned a 50W temperature controlled iron but didn't get on with it, probably because I didn't need the features, and it took up valuable bench space. For the basic soldering I mostly do, ordinary irons are fine. Advanced soldering and repair work is a different story.
An observation about solder tags. Bought surplus 40 years ago, all mine need a good clean before soldering because they're covered in some sort of light grease. Modern tags might be cleaner!
