Posted by Chris TickTock on 19/01/2020 13:56:47:
Posted by Michael Gilligan on 18/01/2020 23:00:22:
Posted by Chris TickTock on 18/01/2020 16:01:20:
I note in the smiths little Torch manual it states 'when using natural gas a minimum of 1 pound pressure is required'. What is meant by 'natural gas'?
Chris
It's the mains gas supplied to a domestic cooker. In my youth, these were supplied with 'Town Gas' aka 'Coal Gas', manufactured in a Gasworks by destructive distillation of coal. It contained Carbon Monoxide and Hydrogen. Natural gas (often associated with oil), comes out of the ground and can be piped more-or-less as it comes. It's mostly Methane. Lots of fun when we switched from Town to Natural Gas because all the burners had to be changed.
The main problem with piped Natural Gas is domestic pressures are low: in a home, perhaps not enough to run a Smiths, but there's a good chance it would. They're just saying 'don't complain if it doesn't work because you happen to have low pressure gas'.
Using a torch there's a subtle difference between heat and temperature. Taking a shower, you want about 20 litres of comfortably warm water delivered over 5 minutes, about the same amount of heat as a kettleful of boiling water. No-one wants boiling water poured on their head, heat yes, burning hot no!
For brazing and soldering heat is wanted rather than high temperatures, and ideally the heat should be cheap. That means not using exotic gases and not using Oxygen, but instead using a big conventional torch that can burn a lot of cheap gas in air quickly. That delivers the energy (heat) needed to raise a lump of metal quickly to brazing temperature, which is only about 450 to 600C. (Soldering is under 450C). It doesn't help to have a small torch burning Propane and Oxygen at 2500C in a tiny intense flame when solder melts at 180C, and the flame fails to warm the surrounding metal!
The Smith's Torch is aimed at a different problem, ie putting a precision flame on to very small work. I'm sure it's excellent. But the Smiths may not get enough gas through it's tiny nozzle to produce the heat needed to braze something the size of your Long Case Bridge. Adding Oxygen will help by increasing the temperature but for brazing rather than welding more heat is wanted, and that higher temperature is unwelcome. Poor joints are likely. At the extreme, a Smith run with expensive Acetylene and Oxygen is more likely to melt Brass than braze it, even acting like a gas axe. With surplus oxygen it will certainly cut steel. Is that what you want? A clockmaker might need a precision torch and a suitable Propane torch, Sievert or similar.
