Posted by Mick B1 on 27/06/2019 09:23:41:
Posted by Blue Heeler on 27/06/2019 08:10:55:
Lots of references to tool grinding show and mention SCA, I've never understood what it does.
If there's any beneficial effect, I think the main one is to create an outward vector on the forces acting on the tool, and hence the crossslide – so as to take up the backlash positively, improving consistency and accuracy on repetitive cuts.
Downside is that it limits working close to the chuck, and will leave your bar with a conical end after parting, potentially wasting (a probably trivial amount of) material.
That's what I think too. A straight tool takes the cutting force at a right angle to the shank, which I think makes chatter more likely. By angling the leading edge a proportion of the cutting force transfers sideways into the body of the shank. Bit like the way an arch bridge is strong because the shape transfers weight smoothly to ground. In other words the angle supports the cutting point better than a straight shank.
May not make much difference until the tool is pushed hard. For gentle and moderate cuts I suspect the performance of straight and SCA tools would be identical. Just a suggestion: if heavy cuts are the goal, maybe carbide is a better choice…
PS See Andrew made the same point while I dithered. Must learn to type and think faster.
Edited By SillyOldDuffer on 27/06/2019 09:47:43
