Hello All!
I am making an exhuast muffler from aluminium. It will comprise of 3 parts; two 'end caps'and an aluminium body.
The body is from 18mm OD tube, the end caps from aluminium stock.
My question is… fitting the end caps, which I intend to press in…. I'll explain.
The ID of the tube is 15.00mm. When I heat the tube (well over 120 degrees) the ID is now 15.10mm. What I intend to do is turn up the end caps ona a lathe, with a shoulder of (say) 15.15mm, heat the tube and then press them in and finish machining the muffler when cool. The tube now grips the end caps.
When the muffler gets hot (attached to a model four stroke engine) then all the aluminium parts should expand at the same rate, keeping the caps in place.
I've looked at commercial mufflers (particularly OS and SC) and they are made with end caps, with no 'weld' being evident.
Should I also reinforce with JB weld or whatever?
Thoughts anyone?
Steve
