See Through Jet Engine
Home Forums General Questions See Through Jet Engine
Viewing 15 posts - 1 through 15 (of 15 total)
  • #603544
    Brian John
      @brianjohn93961
      Forgive me if this video has already been posted but I thought that it might be of some interest to model engineers on this site.
      (887) See Thru Jet Engine – YouTube
      It is not really a question but I did not know where to put it !
      Brian John
        @brianjohn93961
        #603545
        Thor 🇳🇴
          @thor
          I have never seen the inside of a jet running before. Very neat demonstration.
          Thor
          #603546
          David George 1
            @davidgeorge1
            Really good. When you have made parts for a full sized engine it gives you more insight to whst the bits do.
            David
            #603547
              Excellent video, Brian … thanks for sharing it.
              Good to see you posting here again yes
              J Hancock
                @jhancock95746
                Absolutely fascinating video.
                The vital importance of balance and yet in full size , I do believe the roots of the blades of some stages are
                floating.
                How does that work ?
                #603601
                JA
                  @ja
                  Yes.
                  We used to look into combustion chambers operating at atmospheric pressure. One stood beside the exit with a hand beside your face on the chamber side. Then you very carefully looked into the chamber until your hand started getting hot. No one was ever burnt but for other reasons the practice was stopped. One was testing at atmospheric pressure did not mean very much.
                  We also photographed inside chambers at high pressure through windows (made of sapphire I think). Once one broke and incinerated a Hasselblad camera (it was a very old one).
                  Running engines were looked into using high energy X-Rays in real time. You stayed well away from the test bed when that was done.
                  JA
                  Edited By JA on 30/06/2022 11:43:34
                  #603602
                  noel shelley
                    @noelshelley55608
                    AWSOME ! Noel.
                    #603607
                    Brian G
                      @briang
                      A better view by far than the Gunson's "Colourtune", the only window into the combustion chamber accessible to the man in the street (normally at night).
                      Brian G
                      #603615
                      Brian John
                        @brianjohn93961
                        Watching this makes me want to build one just for the sound alone !
                        #603629
                        Gordon Tarling
                          @gordontarling37126
                          Posted by J Hancock on 30/06/2022 10:58:23:
                          floating.
                          The compressor blades usually have dovetail roots and the turbine blades, firtree roots to attach them to the disc that rotates with the shaft.
                          #603630
                          John Doe 2
                            @johndoe2
                            Brilliant, but not at all sure about standing next to it, or even near it while it was running !
                            I don't know what the transparent tube is made of – sounded like glass – but if it shattered owing to the internal pressure and heat, the guy would have lost his eyesight. Hopefully the camera was locked-off and he was well out of the way.
                            Awesome demonstration though.
                            Regarding floating blades on the real thing; I am sure DG 1 or JA will correct me but, some, e.g. the big front fan blades, are a loose fit but they lock into place with centripetal force as the engine is started. They make a right old clanky noise when the wind blows them round on stand, and passengers boarding must think they are knackered !
                            #603642
                            John P
                              @johnp77052
                              Posted by Brian John 30/06/2022 13:07:03
                              Some useful download plans can be seen here from Gerald Rutten (zip files)
                              http://www.gerald-rutten.nl/turbines.htm
                              Photo here of some Wren MW 54 parts and some KJ 66 parts.
                              On the left wren MW 54 ,in the centre KJ 66 milled from the solid
                              compressor wheel and blank behind .
                              New compressor wheels can be found on Aliexpress for less than £20
                              like these here in the 2nd photo.
                              Standard 608 bearings can be used and are good to about 120,000 rpm
                              but have a short life . A cheap alternative is to re-ball a standard bearing
                              with Si3N4 ceramic balls ,the inner race needs to be reground to be able to
                              fit with a phenolic cage or fill the whole bearing to make a full compliment
                              bearing.
                              #603643
                              Clive Foster
                                @clivefoster55965
                                Posted by John Doe 2 on 30/06/2022 16:18:50:
                                Reading down the comments it seems that he has developed his own transparent material that is much safer than a standard glass and additive mix in this sort of potentially dangerous shatter situation. He says he hasn't patented the mix because then he'd have to disclose it. Claims he knows what he is doing and fully understands how to create safe materials but ill advised copies could be very dangerous even though the mix is right. I guess its not just the mix but heat treatment and, possibly, pre-stressing involved.
                                #603646
                                JA
                                  @ja
                                  Fan and compressor blades use dovetails these day (I think there is some clearance). These are complex and very carefully thought out. Turbine blades have almost always used fir tree fixings. Compressor blades on engines designed prior to about 1970 were often held by pins. The floating blades made the heavy clanking noise when the engine slowly rotated.
                                  It is very unwise to be beside a running jet engine including a model jet engine. They are very safe but very very occasionally something happens (and makes the news). The energy levels are very high. In the case of the model in the video the pressure would be no more than two atmospheres across the transparent casing. If the transparent casing failed there would be some of slightly hot debris. The chamber might break up. Its metal temperature would be somewhere up to around 800C. The escaping gas would be between slightly warm and hot, hot being up to 1200C. The event would be over very rapidly with the engine running down immediately. You may receive some burns. A fire extinguisher would be very useful.
                                  When our trainees/apprentices ran a model engine at work they had to use a full size testbed. I am sure this was dictated by H&S but would have given them an experience of test environments.
                                  JA
                                  Edited By JA on 30/06/2022 17:51:35
                                  Edited By JA on 30/06/2022 17:52:49
