Hi all,
Well, here's the up-date.
It has been quite an eventful journey in changing the bearings. To start with all was going very well, until I put the first bearing on. Oh, it went on perfectly, the only trouble was I forgot to put the Nylon cover on next to the faceplate! Panic!
I must admit there were one or two mild (Yeah, right!) expletives. Okaaaay, remove bearing, put Nylon cover on, put bearing back. Hands up those of you who have never heard of 'Sods law'….. Mmmm, thought so! The bearing would not come off, to make matters worse the %&**&^ thing split into two separate parts. ( For those of you with delicate ears read %&**&^, as 'silly'!!). I did manage to re-assemble it and try it. It worked but was noisy, anyway, I bit the bullet and ordered another bearing. Guess what, I was unable to get the 'silly' thing off again. It had split in two again and I had to resort to very, very carefully grinding the housing down on opposite sides until it was thin enough to gently tap it off. I couldn't use the press as there was no clearance between what was left of the bearing and the shoulder of the spindle. The good news is that it is all back together and is working extremely well.
Lessons learned: 1. Check everything twice before you start a job.
2. That 'hindsight' is a wonderful ability to have! Looking back, what I should have done was to have cut the Nylon cover, slipped it over the spindle, then 'superglued' it and saved myself a lot of stress!!
3. Panic is NOT an ability!!
Cheers, Colin.
