It's a weldable structural steel. S235 is weaker than anything in the old BS 4360. The weakest that had was grade 43, S235 may have been equivalent to a grade 35. The yield stress is 235 N/mm^2, breaking at 350-ish dependant on thickness.
It is gummy, and machines more like 070M20- not very good. Use it for structures not machining.
Try for EN 10277 steel number 1.0715 also known as 11SMn30. That is the Euronorm version of the steel you want, same name & number throughout Europe, even the UK. The number is the German number, the name is the French one. The UK numbers have been lost along the way. For a small comparator look here: http://www.parkersteel.co.uk/Matrix/56/Bright+Round+Metric
Richard
Edited By richardandtracy on 14/04/2017 20:34:26
