Hi, well I’ve used angle grinders ever since I first started working for a living, and I’ve used all the normal sizes from cheap ones to the industrial pro models, and I’ve never come across a a quiet one, even when they are not actually grinding anything, and of course the instructions say that you should wear ear defenders while using them at all times, as well as all the other PPE associated with their use. Cheap ones though, are prone to be noisier and vibrate more than the better quality ones. Of course, they are not the sort of thing designed to be used inside a domestic dwelling.
The very first angle grinder I used, had a cup shape real grinding stone on it, which was a bit of a beast to use, and there wasn’t even a guard around the grinding stone.
Regards Nick.
