Posted by Stephen Rowley on 25/02/2018 07:48:21:…
…a length of Brass in the chuck, I took my first cut only to discover that the cut got deeper the closer the tool got to the chuck.
By how much? A couple of thou? 10 thou? 20 thou?
Over what length? And what was the diameter of the brass?
If it's just a couple of thou, it might just be a matter of shimming the mountings of the lathe bed to get it set straight.
If it's more like 20 thou, you might need to look at headstock bearing adjustment and alignment.
Or if the brass bar is long and thin, it might just be flexing away from the tool at the far end.
All this is presuming you used no tailstock centre, as you have not mentioned it. However, if you did, then the problem may just be a simple matter of tailstock alignment adjustment.
