I don't use polishing cloths in a lathe. It's a bit sad that some schools did this as it will have an impact in all of them what ever is used for polishing. There is nothing safer than a decent length of emery cloth strip and it's what's been used for this for a lot longer than I have been around. Strips of cloth of sufficient length would be ok as would 3m film cut into strips as needed. There is only really any need to hold the ends. I'm sure others do something else at times as I do but …………..
Bores can be managed with some sort of stick with a slot in the end. I usually use a piece of bar.
Afraid I don't but a hand on the end. I might even mount it in the toolpost but it wears very quickly used like that. It can make a very efficient multi point cutting tool especially if rather coarse.
I looked at buying a more modern boxford recently. Ex school from a company that visits lots of schools doing machine maintenance for them etc and also buying machines of them. Manual machines are now very thin on the ground, mostly gone. CNC rules as it's completely enclosed. Sad and mostly down to silly practices that can easily go wrong plus the precautionary principle. One's been mentioned a couple of times – ties is workshops – where the hell were the overalls which should be worn anyway.
One handed filing is amusing. Have a hand / fingers on each end and it's rather difficult to get it to catch anywhere providing it's a suitable size for the work that is being done.The worst thing to do is use a needle file one handed and have the end catch.
People shown in photo's with there head close to a running lathe and no safety glasses is why B'ham has it's very own dedicated eye hospital with no appointment needed. Urgency was gauged as people came through the door. I've known several people who needed a visit sometimes days after the swarf went in – painful as the skin grows over it. It can happen no matter how far some ones eye happens to be away from the work but if a lathe is spitting little hot bits about something is wrong somewhere. I feel that the problem can be much worse when milling.
Edited By John W1 on 13/10/2015 15:01:00
