I recently bought a new mill (Amadeal VM32L – pretty much like a WM18) and it came with the T-Slots having a thick layer of paint.
So thick that the T nuts had trouble entering the slot. A mild bit of brute force sorted that out, but of course the paint is chipped in places.
I wanted to ask if the paint had any real value. I imagine the idea is to prevent corrosion, particularly in the parts of the T you can't easily get to to clean.
However, I had in mind to use the slots for lining things up. There was an article in one of the mags recently about a vice aligner which I quite fancied.
I might also add that this mill seems to attract condensation more than my CMD10 did, though it's hard to compare like with like.
So, should I strip the paint off to expose the metal? If so what kind of stripper should I use?
Or is the paint a necessary protection?
Thanks as always.
Iain
