Myford ML7 headstock diameter
Home Forums Manual machine tools Myford ML7 headstock diameter
Viewing 21 posts - 1 through 21 (of 21 total)
  • #13779
    Paul Smith 37
      @paulsmith37
      Need assistance please
      Paul Smith 37
        @paulsmith37
        Anybody got a Myford ml7 that can tell me the internal diameter of the headstock shaft? Or what’s the biggest round bar that will pass through the chuck and out of the side of the machine. Thanks for your help, cheers Pauly
        #453125
        Steviegtr
          @steviegtr
          I have the super 7 but think they are the same. The tapered end of a 2MT is the size. Unfortunately it is one of the Achilles heals of the Myford.
          Steve.
          Edited By Steviegtr on 19/02/2020 22:52:44
          #453130
          Grindstone Cowboy
            @grindstonecowboy
            This thread may prove useful.
            #453137
            Neil Lickfold
              @neillickfold44316
              less than 5/8 of an inch is how my S7 came, so most likely the 19/32. I have since made a 16 mm carbide tipped reamer and pushed that through the spindle. I did bore it first for the 1st 20 or so mm past the taper of the MT2 when the 10mm starts. I really should have made the reamer 16.2mm oe so to allow for metric bar. I can get 5/8 bar through no trouble, and straight slightly under sized 16mm bar bar stock at a push.
              Neil L
              #453146
              Paul Smith 37
                @paulsmith37
                The reason for the post was I’ve bought a metric ML10 . But to my dismay I tried to put some 16mm bar thru the chuck but found it wouldn’t go. So I measured it and found it to be 15.7 or thereabouts. I was going to check the chuck end but can’t get the chuck off at the moment. I may have to make a Mercedes star style external key to remove the chuck via the jaws and tap it round. So it sounds like because of the mt2 taper they are both the same size. I’d thought of upgrading to a ml7 but aside from the longer bed I doubt there’s much to gain. Cheers Pauly
                #453149
                Mike Poole
                  @mikepoole82104
                  The downside of overboring the Myford spindle is that the morse taper starts to get very short, depending on what you may need to mount this could start to be a problem. Even the standard bore does nick a little bit of the morse taper. I suppose now that many of us have a milling machine the usefulness of mounting live tooling in the headstock has rather diminished and there are workarounds that get over the problem.
                  #453173
                  Hopper
                    @hopper
                    The ML7 spindle bore is 19/32" or 15.1mm.
                    The time-honoured workaround is to use a fixed steady to support larger diameter jobs that are held by the other end in the chuck. EG:
                    So a large bore spindle is a nicety rather than a necessity.
                    Edited By Hopper on 20/02/2020 10:27:35
                    Edited By Hopper on 20/02/2020 10:47:34
                    #453177
                    Paul Smith 37
                      @paulsmith37
                      I thought of doing that ,but the axle I was making was 16mm dia and 500 mm long so wouldn’t go on the bed.I bought a pair of ball raced wheels with a 16mm bore, then bought some 16mm round to mount the wheels, trouble was the bar came up at 16.25 mm. And I couldn’t machine off .25mm
                      #453180
                      Hopper
                        @hopper
                        Ah yes. That's when the extra length of the ML7 could be handy. Or you get real creative about machining down one half then flipping it end for end and doing the other half. Still leaves the two end noggins to be cut off though.
                        #453181
                        Paul Smith 37
                          @paulsmith37
                          So is there anywhere that makes a headstock spindle for the ML10 without the Morse taper and thus giving a bigger bore size
                          #453182
                          Clive Brown 1
                            @clivebrown1
                            My first lathe, a well-used 3 1/2" Grayson, had a 19/32" spindle bore which could be irksome. I put a 5/8" drill down it. This gave a useful improvement and I never saw any downside. The 2MT still gripped well if needed
                            #453186
                            Howard Lewis
                              @howardlewis46836
                              The 2MT bore in the mandrel was the main reason that my ML7 went to a new home.
                              Opening up the bore will slightly decrease the strength and increase the flexibility of the spindle.
                              If you are prepared to accept this; do it!
                              #453202
                              Paul Smith 37
                                @paulsmith37
                                What did you replace it with?
                                #453203
                                Mike Poole
                                  @mikepoole82104
                                  I would leave the spindle and get familiar with using the fixed steady, the next job along will almost certainly be bigger than the spindle hole no matter how far you dare to push it. Even lathes with large holes have a steady for the job that is too big. If you find that you need the steady too often then perhaps it’s time to change the lathe for one with a bigger bore but one day you will need the steady.
                                  #453204
                                    Long job like that can be mounted on the cross slide, vertical slide or even held in the toolpost if big enough and then just use a boring head in the spindle or make shift tool holder to reduce the diameter of the end.
                                    #453206
                                    Paul Smith 37
                                      @paulsmith37
                                      I’ve never seen a boring head. I’ll look that up. Ta
                                      #453207
                                      Paul Smith 37
                                        @paulsmith37
                                        Aha…**LINK**
                                        #453210
                                        Paul Smith 37
                                          @paulsmith37
                                          #453237
                                          Howard Lewis
                                            @howardlewis46836
                                            Paul Smith 3,
                                            With retirement looming, the original plan was to replace the ML7 with a Super 7 Sigma.
                                            Very many will be horrified to know that having learned the cost of a Myford Super 7 Sigma, with 4MT mandrel, gearbox, chucks and steadies but incapable of power cross feed, I bought a far eastern product.
                                            My purchase was an Engineers ToolRoom BL12 – 24, which is a Warco BH600 / Chester Craftsman lookalike.
                                            It was delivered, complete with VFD, Chucks, and Steadies, with induction hardened bedways, and a separate power for both axes, as well as the leadscrew, for a quarter of the cost of the S7 Sigma.
                                            So far, it. has served me well, with only a few early life minor problems.
                                            It has been fitted with a shop made Four way rear toolpost, and gearbox input gear which halves the minimum feed rate.
                                            Like so many lathes, once acquired, it is unlikely to be changed; not in my lifetime!
                                            Probably an overkill for most of my work, but it dies all that I need.
                                            #453238
                                            Paul Smith 37
                                              @paulsmith37
                                              Thanks for the reply I’ll have a read up !
