Myford ml7 21 tooth change gears
Home Forums General Questions Myford ml7 21 tooth change gears
Viewing 14 posts - 76 through 89 (of 89 total)
  • #339414
    Jon Cameron
      @joncameron26580
      For reference my lathe has a 20 tooth gear on the spindle and the available gears are, 20, 20, 25, 30, 40, 50, 55,, 60, 65, 65, 95, not including the back gears, or the two gears on a ML7 tumbler that I have.
      Nick Hulme
        @nickhulme30114
        I don't "approximate" threads, if it's right it's right, if not then it's wrong.
        I know lots of people are happy with a very close approximation, God bless them for settling!
        Where else will they "Settle" ?
        Edited By Nick Hulme on 02/02/2018 01:28:48
        #339418
        Hopper
          @hopper
          Posted by Jon Cameron on 02/02/2018 01:06:12:
          My same-era Drummond M-type has the same gears as that, but no 95T. It will cut all metric threads using those standard gears, set up as compound gearing. My standard reference is the the charts in Martin Cleeve's book "Screwcutting in the Lathe". He gives all the needed combinations to cut metric threads with 8tpi leadscrew lathes, within about one thou per eight inches or so!
          I think Rod's chart above and Michael's linked calculator will give the same result.
          #339419
          Hopper
            @hopper
            Posted by Nick Hulme on 02/02/2018 01:27:46:
            Sounds like what Martin Cleeve in his book "Screwcutting in the Lathe" refers to as the enthusiams of "overzealous amateurs".
            In the real world, his "approximation" gearing is accurate to one thou in several inches. Mostly per eight inches or so, in other cases three inches.
            How accurate is your lathe's leadscrew? Six thou per inch variation is not unheard of. Using "perfect gearing" on such a home hobby low-cost lathe (whether Myord etc or Chinese made) is perhaps something like waxing a dirt floor. The "approximate" gearing works just fine for anything one is likely to do at home, or in the average commercial machine shop for that matter.
            #339487
            Nick Hulme
              @nickhulme30114
              Posted by Hopper on 02/02/2018 05:23:03:
              I have the gears for a gear train that gives me the option to work without gearing errors in metric threads, and it's quicker to set up than the approximation options ;D
              Do you introduce errors if you have the option not to?
              #339494
                The biggest fault in production engineering is to work to a greater tolerance than the job demands.
                Working to higher than required precision is a luxury hobbyists can enjoy, but they shouldn't be scorned if they choose not too.
                Nick Hulme
                  @nickhulme30114
                  Posted by Neil Wyatt on 02/02/2018 18:00:33:
                  Neil,
                  It's usually the other way around as you see above where those who prefer working to as close a tolerance as possible are pilloried for it
                  #339496
                  Mike Poole
                    @mikepoole82104
                    Unless you have some very good measuring equipment I doubt the threads produced by the approximations would trouble most people most of the time. It would be interesting to measure how good the threads are produced by a theoretically perfect setup.
                    #339518
                    Jon Cameron
                      @joncameron26580
                      Thank you for the replies, for my accuracy it will be if it works it' close enough, if it dont then it' back to the drawing board. I'l never be able to get accuracy down to microns on an ML4 but if I can get it to under a thou accuracy on any given part then that will be good enough for me. Others might disagree but most drawings are only to +/-0.001" tolerance, others 5thou. So for most application I should be set.
                      #339519
                      Hopper
                        @hopper
                        Posted by Nick Hulme on 02/02/2018 16:27:02:
                        Ah, well if one has the luxury of the correct gears, then of course they are the ones to use. I lie in bed at night and dream of such luxury! smiley
                        #339520
                        Hopper
                          @hopper
                          Posted by Jon Cameron on 02/02/2018 21:33:17:
                          And your threads may well still be more accurate than mass produced hardware store nuts and bolts that seem to work perfectly well. Have fun with that old ML4. There is a perverse pleasure that comes from doing accurate work on such old machinery.
                          #506132
                          Mike Kavanagh
                            @mikekavanagh49516
                            Hi all, stupid question but I've just bought the 34/33 teeth gears to cut metric on my imperial lathe. I'm presuming you have to leave the half nuts engages and run the saddle backwards after each cut?
                            #506223
                              Posted by Nick Hulme on 02/02/2018 18:03:56:
                              Neil,
                              Well perhaps we should respect personal choice either way.
                                Posted by Mike Kavanagh on 09/11/2020 08:38:29:
                                That's the usual approach.
                                It's possible to fit a device that declutches the leadscrew while ensuring relative alignment is kept, but that's a choice for those doing many threads.
