Chris
That's precisely why I asked the question. I need to know the PA in order to make the gears for the screwcutting clutch.
Pace the reply from Andrew Johnston, on my ML7, which I retrospectively gearbox-equipped, I had a foul-up years ago which stripped the teeth on the change gear mounted on the output from the tumbler. This was originally the input into the change-wheel train (before the gearbox was fitted). John S suggests that this stripped gear was 14.5 degrees.
I bought a cheap pattern changwheel to get me going, this was returned to the supplier as being laughably rubbish. I then made a changewheel in cast iron, using the only 20 DP gear cutter of the right tooth count that I had available. This cutter was 20 degrees pressure angle.
So apparently I was replacing a 14.5 degree gear with a 20 degree gear, and then meshing it with 14.5 degree gears. This gear has been in use when screwcutting, and quite often when surfacing (too idle to change back) for over 20 years. I have just looked at the lathe and none of the gears show any signs of distress. The meshing is not tight as it depends on the setting of the quadrant. The arrangement runs sweetly with low noise.
So I stick with my observation in the first post. Within limits of load and speed, gears of different PA but same DP will mesh without too much trouble. It may not be pretty but it works in this context.
In my days in a railway testing lab, when we often had to cut corners in order to get a testing rig built quickly, I used to say "this is fine in practice, but will it work in theory?"
Having said all this, I am still not absolutely clear what PA I have, so I will determine the PA on the gears that will be used with the screwcutting clutch modification. I will do this using the method shown in http://mikesworkshop.weebly.com/change-gear-pressure-angle.html which is accurate enough to distinguish between different tooth profiles.
Incidently, I intend to generate the gears for the clutch unit with my shaper suitably modified, using a simple rack-tooth form tool as described years ago in ME by "Base Circle", the original article can still be found on the internet.
Jim
