Hi guys, I know this topic is a few years old but it might well be worth replying to for posterity. I have a passion for Boxford shapers & have bought & sold several over the years. I still have one now. The way I move them around is as follows.
In the workshop I simple use a long crow bar, about 6 feet long to lever the shaper up until I can get blocks of wood under each corner. I then have many rollers made from scaffold poles that I then place under the shaper. The machine can then be quiet easiely skidded around on the rollers.
For transporting from one place to another I guess I cheat a bit! I have one of the Machine mart engine lifts that will fold up & a Machine Mart motorcycle lift modified with a flat bed made of ply wood.
if you are lucky enough with your truck or van you may be able to lift the shaper straight into the back. Otherwise, I lift the shaper onto the motorcycle lift with the engine lift. Before the lift is made I back the motor cycle lift up against the back of the van, & place said scaffold poles onto the bed of the motorcycle lift.
Once onto the rollers the shaper can be skidded into the back of the van with ease. Removal is just a reversal of the process.
i can manage to do this on my own, & have picked up as many as two shapers in a day.
Elf & safety may not like it…but I still have 10 fingers & toes & the Egyptions didn't have Elf & safety & look what they managed.
The wife & I have managed to offload & move quiet heavy lathes with just the pair of us, an engine lift, some rollers & a couple of crow bars & farm jacks.
Not to make light of safety, these machines are heavy, but with a bit of careful planning & for thought its surprising what can be done.
Regards R
