morse taper sticking
Home Forums General Questions morse taper sticking
Viewing 25 posts - 1 through 25 (of 35 total)
  • #132511
    ronan walsh
      @ronanwalsh98054
      The 2mt collet chuck i use in my tom senior mill vertical (knuckle type) head keeps sticking in place. Normally on any mill (usually r8 tools) i have used i slacken off the drawbar a couple of turns and give it a light tap of a brass or copper hammer and the tool pops right out no problem. I have tried the same thing with this morse taper tool and it stubbornly remains in place. If i have to resort to hitting the drawbar harder it knocks the head out of alignment. I have tried leaving the taper dry and with a very thin smear of copper grease but it makes no odds.
      Is this something you just have to suffer with morse taper tools, it doesn't happen with the tailstock on the lathe or my pillar drill. Any solutions ?
      ronan walsh
        @ronanwalsh98054
        #132512
        Thor 🇳🇴
          @thor
          Hi Ronan,
          R8 is a self releasing taper, morse tapers are not. On my milling machine I have a MT 3 taper and never tighten the drawbar much. This usually makes it fairly easy to release the tool shank. I have never had a tool come loose in my milling machine, but sometimes a heavy copper hammer is necessary.
          Thor
          Edited By Thor on 13/10/2013 05:27:09
          #132518
          Lambton
            @lambton
            Ronan,
            Thor s probably correct. You are most likely tightening the draw bar too much. Morse tapers are self gripping and the draw bar should only be nipped up very lightly, just enough to prevent the taper loosing its natural grip. In practice use a short spanner and turn it only a few degrees, do not "crank it up".
            The main problem if you have to flog the drawbar is damage to the spindle bearings which take all the force from the hammering.
            I have a Tom Senior E type mill and I have made a series of adaptors that fit in the Clarkson chuck rather than in the 2 Morse socket. This means that many jobs can be done without having to remove the Clarkson chuck thus minimising the number of times a drawbar has to be tapped out. These are 3/8" drill chuck, fly cutter arbors, holders for FC3 cutters etc. See my article on the subject in MEW 133.
            Eric
            event any
            #132530
            Bazyle
              @bazyle
              Copper grease is rather thick for this application and not providing any advantage. Use thin oil. You could just try an experiment bluing the inside of the taper and inserting your best taper tool to see if there is a poor contact pattern. It might be that a bad taper was rammed in or a 'spin' at some time has resulted in a ridge that now grips the tapers.
              #132533
              ega
                @ega
                I like the idea of Thor with a big copper hammer (apparently named "Mjolnir&quot but not the practice of "flogging the draw bar". My very basic mill/drill is now fitted with a self-extracting draw bar which I use to remove most tooling; other tools are removed via the slot in the quill with the appropriate tapered drift.
                On the Super Seven I use a lever-operated tailstock with resident sliding hammer but I still have to tap the drawbar for headstock tooling.
                I never oil or grease MT tapers. There was a suggestion that suspect shanks should be inserted with a paper slip but I have never tried this.
                #132535
                ega
                  @ega
                  Does anyone know why a standard right bracket becomes a Smiley (as in my recent post in this thread)?
                  #132537
                  speelwerk
                    @speelwerk
                    When using the morse taper of any spindle make sure you do not place a cold collet/centre etc. in a warm spindle. removing after use will then become very difficult. Niko.
                    #132541
                      Posted by ega on 13/10/2013 11:52:23:
                      Yes, unfortunately … it's a "feature"
                      a quote mark, immediately followed by a closing parenthesis is interpreted as a smiley.
                      … one of many such.
                      ega
                        @ega
                        Michael Gilligan:
                        Thanks for enlightening me. It would be helpful if there were a list of these features or, better, the facility to turn them off.
                        #132544
                          Posted by ega on 13/10/2013 13:07:07:
                          Michael Gilligan:
                          We keep trying … but apparently users on the other MTM forums like the "feature"
                          jason udall
                            @jasonudall57142
                            It is suggested. That draw bars are used with morse taper to stop the side loads causing them to walk out…
                            Might this be more gentle than “flogging”
                            #132555
                            Russell Eberhardt
                              @russelleberhardt48058
                              Michael Gilligan:
                              Just insert a space before the close bracket. I know it's poor grammar but it works.
                              Russell.
                              #132557
                                Unfortunately there is a long list of keystroke sequences to avoid.
                                Here are a few
                                ega
                                  @ega
                                  Michael Gilligan:
                                  Again, thanks. Oddly enough I couldn't see Wink 2 in that list.
                                  Russell Eberhardt:
                                  Thanks for the workaround.
                                  A further thought: the instruction to substitute the unwanted smiley is not executed until the text is posted which is perhaps why some forums incorporate a preview. The preview also gives an opportunity to deploy the blue pencil before going public.
                                  #132561
                                  Gone Away
                                    @goneaway
                                    Posted by ega on 13/10/2013 16:48:00:
                                    Sounds like that old dichotomy from the working days:
                                    You can either work around a bad system and get the job done. The powers that be will sit back happy that the system works and you'll be "working around" forever.
                                    Or you can work exactly to the bad system, showing it up for what it is, and probably getting it corrected in short order. Short term pain for long term gain.
                                    Bear in mind that this problem is eminently fixable – it can be set up to require smileys to be pulled from the drop-down only. The reason it isn't is because some ("texting-types&quot on associated websites object to the extra effort of clicking on the smiley icon and insist on entering them from the keyboard)
                                    Edited By OMG on 13/10/2013 17:26:03
                                    #132562
                                    ronan walsh
                                      @ronanwalsh98054
                                      No, i have checked the bore of the vertical head and its fine and thankfully made from hardened steel, the taper on the collet chuck is only a few months old and again appears to be hardened steel and nicely finished with no rings or marks. I don't take out the collet chuck often , but occassionally need to if i want to use a boring head or drill etc. I'll use less force tightening the drawbar in future, but i found before that the taper could work its way out while cutting. Somehow i don't think morse taper is ideal at all for this particular task.
                                      #132564
                                      Peter Tucker
                                        @petertucker86088
                                        Hi Ronan,
                                        If you make a pair of split wedges to fit between the spindle and chuck you will find they will extract your MT much less violently.
                                        Peter.
                                        #132567
                                        Bazyle
                                          @bazyle
                                          The use of grease is what makes it come loose. Because it is thick it can't squeeze out of the way easily so either it oozes out in use or you have to use excess force to get the grip.
                                          #132574
                                          ronan walsh
                                            @ronanwalsh98054
                                            Posted by Bazyle on 13/10/2013 18:49:15:
                                            There was no grease on it when it became loose, thats why i thought it would not matter using a little grease.
                                            #132579
                                            Emgee
                                              @emgee
                                              Peter's idea of wedges is great, also you may be able to locate a collet chuck with a self ejecting collar, they were made by Clarkson and had an external threaded ring at the back of the chuck that when rotated applied pressure to the spindle end/column so forcing the chuck from the spindle. I did use Mr Thor's copper end on the 3/8" drawbar to remove MT3 tooling from a Victoria mill for many years, I didn't notice any bearing damage but agree that could be a problem.
                                              Emgee
                                              #132608
                                              Lambton
                                                @lambton
                                                "Somehow i don't think morse taper is ideal at all for this particular task."
                                                Ronan,
                                                Your are quite correct the 2 Morse taper is not ideal for this application in general however the better options of R8 or International taper systems are too big to be used on small milling machines – so we are stuck with 2 or 3 Morse.
                                                Eric
                                                #132623
                                                Dusty
                                                  @dusty
                                                  Hi Ronan
                                                  From what you say If the taper was (walking out) when milling I would venture to suggest that the taper on your collet chuck may well be slightly large at the small end. It has already been intimated that you should check the tapers one against the other by blueing. Do not use excesive amounts of blue on the socket (you should barely see the blue) as it could lead to a false reading. Clean both internal and outside tapers thorouly before blueing with something like meths. The other cause could be excesive side load on your milling cutter. i.e. blunt cutter, to large a cut, or to fast a feed.
                                                  #132634
                                                  Lambton
                                                    @lambton
                                                    Dusty,
                                                    From what Ronan has said there is nothing wrong with the taper on his collet chuck.
                                                    It is well known that an unrestrained Morse taper tang, even when properly fitted into a socket, will work loose due to the repeated change in side load imposed on it by the milling operation. This is why milling machines have a drawbar to retain tapered attachments.
                                                    The important point is to only tighten the drawbar to the minimum amount to retain the tang.
                                                    Over tightening a drawbar achieves nothing other than to make it very difficult to remove the tang without a lot of brute force as Ronan experienced.
                                                    By the same mechanism a milling cutter will work its way out of an ordinary drill chuck no matter how hard it is done up. This is why we have ER, Clarkson or Osborn milling chucks.
                                                    Eric
                                                    #132638
                                                    Speedy Builder5
                                                      @speedybuilder5
                                                      Problem of using a pair of wedges (If not used in the hole of the quill) is that they can remove the chuck from the morse taper tang, leaving the tang still stuck in the quill.
