Posted by noel shelley on 13/02/2021 23:19:25:
The OP says topslide and crossslide screws – I think. PB may be rather hard.
Yes indeed. Phosphor bronze will prematurely wear the non-hardened feedscrew. That is why Myford and many other lathe manufacturers used brass or Mazak (zinc-aluminium alloy) for half nuts and feedscrew nuts. The nuts are sacrificial: they wear out but do not wear the feed screw as much as a harder material would. I make my own halfnuts and feed nuts/inserts from brass. They will outlast me at this stage of the game.
Myford and some private sellers still sell the brass feedscrew nuts on their site and on eBay. Search for "Myford feed nut" and "Myford feedscrew" to find them. Leadscrew generally refers to the big 'un along the bed only. EG: FEED NUT
You should be able to measure the amount of wear on the screw's thread itself with a dial indicator showing the slice movement back and forth at different points on the screw engagment with the nut. Usually the ends are pretty much unworn so compare that reading with the area engages in the common operating position. Myford still sells the complete feedscrew with nut kits if needed.
Not sure about Myford's stock/availability in time of plague though. But at the end of the day, unless the nuts are totally worn out, they will not affect the performance of your lathe. The slack is taken up by cutting forces as soon as the tool engages. You just have to remember to turn the dial past the point of backlash if resetting a cut etc. Standard turning procedure anyway.
Or you could buy a length of Acme threaded rod of suitable size and machine the ends to suit. UK suppliers have been mentioned in previous threads on here.
Edited By Hopper on 14/02/2021 09:02:07
Edited By Hopper on 14/02/2021 09:13:54
