Micro drilling
Micro drilling
Home Forums Beginners questions Micro drilling
  • #375347
    Roger Hulett
      @rogerhulett83124
      I need to drill a wire gauge hole in a piece of brass rod. I have faced off the rod and polished with 300 emery to ensure there are no blemishes. How do I accurately "spot" the rod to ensure the drill bit drills true,and are there any other tips around.
      Roger Hulett
        @rogerhulett83124
        Drilling very small holes in brass
        #375348
        Roger B
          @rogerb61624
          How big and how deep? I have got down to 0.2mm using a 0.5mm centre drill for spotting.
          #375351
            What wire gauge as 10swg is not exactly small?
            I drilled 0.3mm the other week, faced, small spot drill and then in with the 0.3mm bit.
            #375356
            not done it yet
              @notdoneityet
              Is the hole to be in the centre of the rod – or somewhere else?
              #376329
              Roger Hulett
                @rogerhulett83124
                Yes,the hole is in the centre of the rod,similar to the set up of JasonB's photo. I don't seem able to get the spot drill to form a sharp enough recess to stop my micro drill wandering all over the place.
                #376330
                Roger Hulett
                  @rogerhulett83124
                  Having reread Roger B's post I think I need a smaller centre drill.
                  #376333
                  Martin Kyte
                    @martinkyte99762
                    You can get centre drills that are really small.
                    ASA00000 has a 0.25mm pilot.
                    However you should find that micro drills will go right down a small Jacobs chuck so you only need a couple of mm protruding. It's amazing how stiff this makes them. Usually stiff enough to form their own centre. Once this has been done the drill can be withdrawn sufficiently to drill to required depth.
                    regards Martin
                    #376339
                    Roger B
                      @rogerb61624
                      Have you checked the points of your drills with a magnifying glass? The first cheap micro drills I bought had non existent points. The Titex ones I am now using are excellent.
                      #376365
                      Rod Renshaw
                        @rodrenshaw28584
                        Hi all
                        Centre drills are not ideal for spotting holes and they get less ideal as the hole gets smaller ( for example, the pilot gets very fragile.)
                        Better to use spotting drills – made for the purpose, with much stronger points and they are available in a wide range of sizes down to very small.
                        For example, "Kyocera" , a Japanese company, list them as small as 0.005" diameter (on an eighth-inch shank) and since you only need to use the point these would probably enable one to make a spot of only about 0.001" diameter if that was needed. Need good bearings in the drilling machine though!
                        Google "Micro spotting drills" Not sure about easy availability but someone will stock small spotting drills in the UK.
                        Rod
                        #376377
                          I tend to use the Americam Keo brand spotting drills, 1/8" one started that 0.3mm drill in the pic above OK. They have a smaller "flat" than other makes. Keo in the front. I only use Ctr drills where the 60deg seat is needed.
                          #376410
                          Sam Stones
                            @samstones42903
                            May be a bit late in the day Roger but …
                            I'd use the tool post instead of the tail stock chuck, while shaping a HSS tool bit with very acute ‘clearance’ angles. Alternatively, grind off half a (scrap) drill and fit that into the tool post.
                            I've never used a graver, but that could produce the necessary conical concavity.
                            Sam smile d
                            #376423
                            Tim Chambers
                              @timchambers76147
                              This is an alternative way;
                                Posted by Sam Stones on 17/10/2018 21:58:44:
                                Very simple process … See the short sequence starting at 1min 30sec, here: **LINK**
                                They're demonstrating carbide gravers, but a good steel one is adequate.
                                  Posted by Tim Chambers on 18/10/2018 00:15:25:
                                  Thanks for that link, Tim yes
                                  I see that the price of the plan has increased somewhat
                                  #376476
                                  Robin
                                    @robin
                                    Posted by JasonB on 10/10/2018 15:09:10:
                                    That looks so far out it isn't true (as they say).
                                    Perhaps it is the camera angle or something surprise
                                    #376538
                                    Sam Stones
                                      @samstones42903
                                      Another gem of yours Michael! That's just how I imagined.
                                      Where do you find them?
                                      Sam smile d
                                      A great link too Tim. Thank you.
                                      #376548
                                        Posted by Sam Stones on 18/10/2018 21:49:46:
                                        'Eternal Tools' is a regular advertiser in the Horological Journal and I just followed my nose one day.
                                        It's a nice little demo, so I remembered it.
                                        Roger Hulett
                                          @rogerhulett83124
                                          Thankyou everyone, problem now fixed. I followed Martin Kyte's instruction re spotting,worked perfectly. trued up the point on the micro drill,ensured that there was no play on the brass rod and bingo,a nice clean hole.
                                          Thanks everyone.
                                          #376692
                                          Sam Stones
                                            @samstones42903
                                            Although largely intuitive to many of us, it is worth mentioning in this context (and for lathe work in general), that the stiffness (resistance to bending) of a round bar, projecting from a chuck (cantilever style) is nonlinear in relation to both its length and its diameter.
                                            Although more complex when considering for example a fluted drill, the stiffness of a round bar relates to the cube of the length and the fourth power of the diameter.
                                            Put simply …
                                            Halving the length (overhang) increases the bending resistance by eight times.
                                            Halving the diameter decreases the bending resistance by sixteen.
                                            I'm pleased to know Roger, that your drilling project was a success.
                                            Sam smile d
