ME tapping dril sizes
Home Forums Beginners questions ME tapping dril sizes
  • #6520
    JC Uknz 1
      @jcuknz1
      JC Uknz 1
        @jcuknz1
        I am getting a ME 1/4 x 40 taps so in the first place need to know the tapping drill size for them but also wonder about a link to a site giving all ME tapping sizes. Hope you can help
        #108627
        Thor 🇳🇴
          @thor
          Have a look at Harold Hall's website.
          Thor
          #108628
          JC Uknz 1
            @jcuknz1
            Thankyou Thor for that quick reply … you have given me a link to a very valuable site
            #108634
            Terryd
              @terryd72465
              Hi (sorry to be impersonal but I don't have a name to address you properly),
              It would be worth installing a copy of Alan Munday's Model Engineers Utilities on your PC. It has a lot of extremely useful data (including data for most screw threads you are likely to need). I cannot recommend it highly enough. best of all it is a free download from here.
              Best regards
              Terry
              Edited By Terryd on 14/01/2013 07:27:06
              #108638
              HomeUse
                @homeuse
                Hi Terryd – I had a copy of the Utilities on my Old PC – Now I have been updated to A MAC secret by my more modern offspring it wont download crying 2 – !!!!! Modern Technolagy !!!!angry
                #108639
                Terryd
                  @terryd72465
                  Hi H,
                  ( a proper name would be nice wink 2) there are programs which allow MACs to emulate Windows machines, I'm not sure if they will work for Alan Munday's utilities but it may be worth a try.
                  Terry
                  #108640
                  Ziggar
                    @ziggar
                    asking a Mac user to install anything MS on their machine is like asking a vegatarian to chomp down on a chicken sandwich …..
                    probably the main reasoon for swapping from a PC to a Mac is to get away from MS
                    #108641
                    Ziggar
                      @ziggar
                      and to asnswer the opening question :–
                      there are _many_ websites and webpages dedicated to giving you the needed tapping sizes if you use Google to search for them
                      #108649
                      HomeUse
                        @homeuse
                        All is not lost as the OLD PC is still in use – Still have to use it for TurboCad – MAC version is like running up the down esculator – That is unless any Mac user out there can enlighten me.???
                        #108655
                        Terryd
                          @terryd72465
                          Posted by Ziggar on 14/01/2013 10:58:56:
                          Hi Z,
                          With Mr Mundays Utilities it is possible to calculate gear ratios, spring sizes, pcd,  sine bar calcs, sheet metal bending data, compare drill sizes, cutting feeds and speeds, as well as easily get thread data, and very much more, all with a couple of clicks in one place with no need to Google anything.  perhaps I'm just lazy
                          For the record, I am a MAC user (+iPhone, iPad, etc) but when I need to run programs that are only available for Windows I am quite willing to use an emulator – which is definitely not the same as using Windows.
                          Best regards,
                          Terry
                          Edited By Terryd on 14/01/2013 14:16:49
                          #108659
                          Russell Eberhardt
                            @russelleberhardt48058
                            Install "Wine" on your MAC. It will enable you to run most Windoze programes directly. Failing that you could install VirtualBox which will enable you to actually install Windoze on an emulated virtual computer.
                            Works fine here on my Linux computers.
                            Russell.
                            #108668
                              Posted by HomeUse on 14/01/2013 12:06:50:
                              I suggest you leave TurboCad where it is, and install DraftSight on the Mac.
                              HomeUse
                                @homeuse
                                Hi M G – ? Is DraftSight any good for Architectural Drawings
                                #108678
                                  Posted by HomeUse on 14/01/2013 16:00:33:
                                  It's only 2.5D … but is remarkably like a legacy version of AutoCad. Definitely worth a try at the price
                                  If you need full 3D presentation; have a look at SketchUp
                                  thomas oliver 2
                                    @thomasoliver2
                                    My reference handbooks show that since the thread size of ME x40tpi is constant, the tapping drill will in all cases be 1/32in less than the nominal size, and this will give 97% engagement. TomOl
                                    #109813
                                    Ian Sugden
                                      @iansugden63787
                                      Posted by Terryd on 14/01/2013 07:26:29:
                                      Best regards
                                      Terry
                                      Anyone got this program to run on windows7?
                                      All comes up with black shaded squares
                                      #109818
                                      Steambuff
                                        @steambuff
                                        Runs fine on Windows 7 here ….. remember to install as administrator
                                        Roderick Jenkins
                                          @roderickjenkins93242
                                          Posted by thomas oliver 2 on 16/01/2013 19:40:01:
                                          97% engagement is asking for broken tap! 5.7mm gives 80% or 5.8mm 65% (from Tubal Cain's "Drills Taps and Dies"
                                          Rod
                                          #109838
                                          Ian Sugden
                                            @iansugden63787
                                            Posted by Steambuff on 23/01/2013 20:30:29:
                                            It only unzips the file and not installsfrown
                                            #109840
                                            Steambuff
                                              @steambuff
                                              Ian,
                                              Unzip the file (as administrator) into any folder you wish ….
                                              Once it it has unzipped it is ready to use … using Windows Explorer, navigate to the folder you unzipped the files into …. Then double click on the ModelEngineersUtilities.exe file.
                                              If you want an icon on your desktop then right-click, select 'Copy' and then hover over your desktop, right-click and 'Paste short-cut'
                                              Ian Sugden
                                                @iansugden63787
                                                I have done that Dave
                                                but the background is black and I cant see half the text
                                                #109853
                                                mechman48
                                                  @mechman48
                                                  Tried to download; running Vista…'CRASHED MY PC' !!! B****CKS, ..will keep my Newnes Engineers pocket book, Presto drilling & tapping ref book, MEW drill & tap ref.charts (early years)..
                                                  George
                                                  #109859
                                                  David Littlewood
                                                    @davidlittlewood51847
                                                    Guys,
                                                    Listen to Roderick, he's the only one who has given the correct advice so far. Most thread tables give tapping drill sizes which are too small; this dramatically increases the risk of tap breakage, especially if they are not perfectly sharp. This is the worst for ISO metric threads (where the fact that the taps are bigger than nominal size is an added factor) but this is true to some extent for all sizes.
                                                    Buy the book he recommends, it'll be worth it, it's only about 5 quid!
                                                    David
