Got involved with resurrecting a Honda 536HRD self propelled rotary mower after several years hibernation. Previous fiddlers were unable to get the hydrostatic drive going.
Filling the drive box with oil and bleeding the air out, a right pain getting all the air out too, got things moving but its clearly not working properly.
If the control cable is pulled up tight the beast will drive at a single, fixed, speed close to flat out. Drive engages with something of a jerk and the rear wheels generally lock against reversing so it can't be pulled back. The speed change lever also tends to spring back to the slow position when drive is engaged but it continues to run at the single speed.
By very careful adjustment its possible to get things set so the rear wheels are usually free to reverse and the drive usually operates. But only at either its preferred high speed or a very slow crawl. Sometimes a bit of manipulation of the controls is needed to get it moving at the higher speed.
Sounds like something deranged internally on the control side. I have a download of the workshop manual and disassembly doesn't look too horrible.
Can anybody advise as to what I should be looking for and how to fix things. Word on the street is that these things are generally treated as unrepairable by the trade and simply replaced.
Thanks
