Posted by Ian S C on 19/11/2011 09:55:05:
Vince, how about using an oscillating engine as the pump, driven by another slightly bigger oscillating engine. It could be made similar to a V twin, with one cylinder driving, and the other pumping. Ian S C
this was my original thought, but if it can be made without any rotating bits there will be less wear and simpler to make, its just getting the balance between the air pressure, the spring strength and the force needed to move the oil.
I may start with a strongish spring and high air pressure and see if i can get that working and then reduce until it won’t pump any more, then up it a bit. just means having a load of springs of differant strengths but all the same dimentions and/or have a variable preloading on the spring
The oil to be pumped is used cooking oil, the one way valves i have ordered are for 6mm pipe but i can get larger if i need to reduce the resistance of the oil flow part of the system.
Thanks for all the idea’s
