Sorry Andrew all down to semantics.
If I get a 1hp motor and run it at 50 hz, 1425 revs for a 4 pole and put it on a brake I will get x lbs/force out of it so that is that the torque is.
Now if I drop this to 25hz and approx 720 revs and put it back on the brake I'll get far less that x lbs/force so how can that be constant ?
It will be constant to 25hz.
Years ago we used to make ink mixers, just like a food mixer on steroids, some had direct drive with inverter control, some had geared motors with inverter control.
Over the years we made literally hundreds of these. That may the inverter suppliers, IMO at the time put us on dealer rate. Their tech guy spent many hours tuning these to get the best out of them.
Printing ink is a funny substance, when it goes in the tub it's a paste or a mixture of pastes depending on type colour etc. These mixers have to start at low revs and as the ink warms up thru friction it gets thinner and you can then increase revs.
Because of this you are starting at the worst point as regards an inverter motor hence some of the larger ones having to have geared motors. It was always touch and go and we were right on the limit with these things as the limiting factor was they had to run off single phase as most were in small mixing rooms with no three phase.
The tech guy is still a personal friend and often calls in for a coffee when in this area. Anyone who knows what he's doing with modern inverters will all the different parameters can do wonders with them.
