Guhring tooling reputation
Home Forums Workshop Tools and Tooling Guhring tooling reputation
  • #219034
    Rainbows
      @rainbows
      My usual brand for drill bits is dormer but recently got a Guhring 14mm twist drill. Anyone here got an opinion either way on the quality of them? Couldn't find much on the internet except their website so I suppose they usually sell direct to industry.
      Rainbows
        @rainbows
        #219036
        Rik Shaw
          @rikshaw
          A top brand. I have a fair bit of their tooling and it is quality stuff.
          Rik
          #219038
          Raymond Anderson
            @raymondanderson34407
            Yes, i'll second that. Guhring gear is top drawer . In the same drawer as Titex , Emuge Franken, and others.
            I have a lot of their Drills both Hss and Carbide, as well as quite a few coated taps. Guhring are made for
            production so buy without fear.yes.
            #219047
            Thor 🇳🇴
              @thor
              I don't have twist drills from Gühring, but I have milling cutters, they are good. So Gühring tools get a thumbs up from me.
              Thor
              #219049
              mechman48
                @mechman48
                Have a number of Guhring small drills myself; the quality is top notch, no wobble, straight as a die, sizes drilled within .001" not oversized, the only trouble is their price but if I can 'obtain', 'be given' any tooling by them I will grab it.
                George.
                #219051
                Emgee
                  @emgee
                  As all comments have said, top quality tooling.
                  Emgee
                  #219060
                  Chris Evans 6
                    @chrisevans6
                    Last set of Guhring drills I bought for work all needed grinding before they would cut. I got the Rep into work to show him and he took them away. He gave me a replacement set that where fine and allowed me to keep the first set to take home. I am still using them 3 years after retirement.
                    #219063
                    Ian Hewson
                      @ianhewson99641
                      First class drills, used them for drilling thousands of 2mm holes in bolt heads for lock wires, sharpen up well and last forever.
                      #219065
                      Rainbows
                        @rainbows
                        It was listed as only used a few times and I think the seller must have reground it since it was last sharpened. For £8 it was cheaper than I could get a standard Dormer 14mm bit and only slightly more than a cheesegrade unbranded one.
                        #219067
                        Anonymous
                          I have some of their drills, taps and milling cutters; never had any complaints about them, even in tougher materials like 316 stainless steel.
                          #219083
                          bodge
                            @bodge
                            Guhring milling cutters & drills available from MSC industrial supply co . often they have Guhring stuff on offer on their sales flyers they have online . Hertel drills & milling cutters are also pretty good too !
                            bodge
                            #219268
                            Neil Lickfold
                              @neillickfold44316
                              Guhring make a huge range of drills, some for specific materials. We use a lot of Guhring drills at my place of work and we have different ones for different materials. They are very well made tools and if you run them correctly get a lot of holes drilled per drill. They also drill very well to size also. Once re sharpened if they are not recoated, then I use the feeds/speeds for the uncoated drills.
                              Guhring also offers custom tooling for specific tasks as well, that most other companies do not offer to do.
                              David Clark 13
                                @davidclark13
                                Guhring are good drills if you can afford them. Used them for years for hardened steel airplane components.
