Gauge Glass with Red line
Home Forums General Questions Gauge Glass with Red line
  • #24437
    Dave Powell 2
      @davepowell2
      Dave Powell 2
        @davepowell2
        Hi folks, I stupidly managed to break my gauge glass during a boiler test yesterday and am struggling to find a replacement. It's 7mm diameter, it had a thin red line down it which made it really easy to see the water level. All the usual suppliers only seem to do the clear stuff. Anybody know where I can get some? Thanks in advance.
        #229790
        OldMetaller
          @oldmetaller
          Hi Dave, Live Steam Models-
          http://www.livesteammodels.co.uk/
          – have what you want on p. 35 of their supplies catalogue.
          John.
          #229792
          Steamer1915
            @steamer1915
            Hi Dave, You could always try:-
            Barry Boyce
            Yorkshire Model Engineering Supplies
            Hull
            Yorkshire
            Business Phone Number: 01482 786 534
            Best regards,
            Steve.
            #229803
            michael howarth 1
              @michaelhowarth1
              Polly Model Engineering 0115 9736700 stock 7mm red line.
              #229816
              julian atkins
                @julianatkins58923
                hi dave,
                schellbach gauge glass is more brittle. can i suggest you carefully check alignment of the top and bottom fittings. also dont let the bottom end of the glass touch the recess in the bottom fitting.
                cheers,
                julian
                #230011
                Dave Powell 2
                  @davepowell2
                  Thank you for your replies, Gentlemen. I had looked at the Polly catalogue but did not find it in there. I will give them a ring today and get some in. The reason the last one broke is that at full heat the drain cock went really tight. On trying to open it the bottom fitting turned and cracked the glass. I think I am very lucky that disaster did not ensue. We aborted the steam test at that point and I came home rather sadder than I was an hour previously, when it had passed it's hydraulic test. Oh well, that's life
