Hi All
I'm hoping someone has had a similar experience and may be able to offer some advice or direction.
In the space of one week both the x-axis power feed motor and spindle motor have failed on my milling machine (G0704 type – 750w motor)…bad luck indeed!
I've already replaced one motor in the power feed unit and bought a second spare at the same time. Tried fitting that one but it's also dead, or I've damaged the unit more that I thought. I've got a source for a replacement so we'll see.
A few days later, the spindle motor went, this is apparently very common for these machines so perhaps I should be grateful it lasted over five years – the smoke being emitted last week was in hindsight more than a clue of things to come!
A quick search of the 'net proved these are a little harder to source and there appears to have been a variety of motors fitted to these machines over the years. I found a couple of sources for a replacement but I also have an eye on the future – what happens when it fails again at any point over the next few years and parts are even harder to come by? The only reason for continuing with the OE option at this point is to get me up and running whilst I research alternatives, which leads me on to the question…
I plan to convert the mill to three phase, powered by an inverter. I've previously done this for my old Myford S7, current Boxford lathe and Boxford pedestal drill. I love the flexibility and control this solution provides; plus the motors are sturdy, easy to source and relatively cheap, as are the inverters.
Has anyone here converted their chinese mill to run on 3-phase? If so, which motor did you use, how big is it and how are you controlling it? This last part is in reference to the OE switches, is it possible to retain the original look? The on-off switch will need replacing for a momentary version (I think) and I'm not sure about the rotary switch? I'm interested in what can be done.
If all else fails I'll just buy a control pendant from ebay and wire that in, but would really like to keep the original switches if possible.
Thanks for reading…
wrinx
