Martin,
If you work out the floor loading over the full contact footprint of the machine I think you will be quite surprised at how low it actually is in terms of pounds per square inch.
Before we were allowed to start building, I had to quote the ground loading of a 5 foot 6 inch high dry stone wall to the National Trust structural engineer at Fountains Abbey 7 years ago, he was concerned that concrete foundations would be needed below it.
It worked out at no more than that under the foot of a 15 stone man building it and he went away quite happy with my assertion that all the ground preparation needed was to remove the turf layer and build straight off the subsoil. Traditionally these walls settle slightly as the ground below it compacts slightly and left undisturbed, such walls will stand straight and true for well in excess of 100 years.
Dry stone walls of that height have a weight in excess of 1 tonne per metre run, on a base that is 28/30 inches wide. As it happens I was visiting the place yesterday for lunch and a walk round with my wife, that particular wall is as straight as a die, just as it was when we finished it
As another example, there is a road bridge [in Norway I think] that is built on polystyrene blocks, how unlikely is that!
Regards Brian
Edited By Brian Wood on 21/12/2017 11:53:06
