Have a Norton 6DB, 6 tons load, very big, very heavy. Cost me nothing more than effort getting it home. 90 degree bends in 6 x 50mm steel flat (grade 43/S275) possible when cold with a bend radius of 6-8mm. Only using angle iron as the tooling. Quite impressed with mine, but it was a monster to get to the workshop because it's very top heavy.
Only thing to look for is a reasonably intact, unworn & rust free main thread. Mine has a secondary thread on the outside which has a stop. You can use it without the stop, but it's better not to. Most are so heavily built that loosing 1/4" to rust won't affect their usability or strength seriously. A wire brush & some paint will double their value.
Beyond that, they are so massively built it's unlikely anyone can abuse them by hand operation. If there is wear on the plunger, it could probably be shimmed out easily enough.
Richard
