Posted by Haggerleases on 17/05/2019 20:07:32:
… and what sort of accuracy is required?
I agree a mini-lathe would be big enough, and it has most of the features needed. The most obvious omission on the mini-lathe is a slotted cross-slide, not fatal, but certainly a nice to have. Next size up would make the job easier, and bigger lathes tend to add features like gearboxes, powered cross-slides, a clutch, and bigger dials. I'd say a mini-lathe is about the minimum needed, and a bigger machine would make the job much easier.
Accuracy is an interesting requirement, and perhaps – within reason – it's one you don't need at all.
The reason I suggest that is because most model makers and home workshops use 'fitting' rather than precision engineering techniques. Because people are expensive, industry has long since moved away from craftsmanship to making tightly specified interchangeable parts. This method eliminates expensive fitters by working accurately within well specified tolerances . Wheels can be made in one factory, axles in a second, assembled together in a third, and spares can be swapped without fuss.
This is not what goes on in my workshop. I would drill a hole in the wheel of about the right size to take the axle. Then I'd carefully turn the axle down to just fit into the wheel. With a little experience it's possible to make anything between a tight press-fit and a loose running fit. Nothing is measured accurately and the lathe doesn't need to be accurate because the wheel is used as the gauge. The method depends on comparison rather than accurate machinery, and it can produce high quality results. The disadvantage is fits made this way can't be swapped.
Although the old timers did everything this way with simple tools, much time and effort is saved by owning a digital caliper, micrometer and an unworn machine fitted with trustworthy dials or a DRO.
Simply put, an imperfect lathe, whether Far Eastern made down to a price, or a worn industrial machine, can still produce good results. It's more to do with technique and operator skill than the machines. An expensive tool-room lathe might be a pleasure to use but it's trustworthy accuracy is unlikely to be essential in a hobby workshop. On the other hand, a badly worn, damaged, too basic, or too-cheap machine is likely to frustrate the operator. But it's more about slop, inconsistency, poor finish, continually having to fiddle with gibs and other irritations than lack of 'accuracy'.
Be interested to see what experienced machinists think of this view.
