Posted by Chris Trice on 26/12/2018 19:17:41:
While you're here Graham, I noticed (in one of your books) you have (had) the Emco Maximat tool post grinder that appears to have the same motor as the Compact 5? Is this the case or is it one of the smaller ones as used on the vertical milling attachment, thanks?
Hello Chris,
My apologies for not responding earlier, I have only just read your post.
It is true I do have an Emco SOD toolpost grinder for the Maximat Super 11. The motor on this attachment is much smaller than the C5 main motor. However the C5 Milling attachment motor is I would say one in the same. Cross checking the Emco part numbers there are a great many similarities between the last 4 digits and the voltages/frequencies. I would in general expect the main part numbers to be different, as usually these first digits apply to the machine type. Also they would need to be supplied in green or yellow colours depending on application.
I had just better add the Maximat V10 uses a derivative of the Compact 8 toolpost grinder which has an AC motor with brushes and not an induction motor as on the Emco SOD. The method of holding the grinding wheels is also different on the V10/C8. This is based on the 8 mm draw-in collet. I am convinced, but not sure, the spindle used in the V10 grinder was the original spindle, supplied as an accessory, for using collets on the Unimat SL.
Gray,
