Diving in to ATC?
Diving in to ATC?
Viewing 2 posts - 26 through 27 (of 27 total)
  • #808810
    Julie Ann
      @julieann
      On Nealeb Said:
      …I haven’t had any chipping problems with my tool setter…
      Neither have I; chipped tools occurred when I was setting zero by touching off directly on the workpiece. Chipping only occurred with carbide tools.
      My electronic tool setter is similar, it does a quick touch and then a slower one to get better precision. Since I bought it from Tormach it is integrated into PathPilot.
      I wrote my own postprocessor; in fact I have two, one with tool change and one without. The one without is needed when I am using the high speed spindle which uses ER11 collets, so doesn’t have a repeatable tool change system. In general that is not a problem as most operations needing the high speed spindle only use one tool.
      Julie
        I’ve only chipped tools when I have hit the wrong button.
        I just use a 20mm block but raise the tool until it just slips under the cutter, lowering the tool onto a block is more likely to damage the tool and block if you come down a bit too far.
