Crowning a pulley for a flat belt Question
Home Forums General Questions Crowning a pulley for a flat belt Question
Viewing 25 posts - 1 through 25 (of 30 total)
  • #531537
    Blue Heeler
      @blueheeler
      Crowning a pulley for a flat belt, been trying on some ali before moving onto brass using the top slide set at 1° + and then set at 1° – and it ain't an easy exercise to achieve a simple crowned pulley!
      Any hints on how to do this? I thought this was going to be really simple, its kicking my arse!
      Blue Heeler
        @blueheeler
        #531541
          Think of the crown as part of a sphere …
          Then produce a suitably dimensioned ball-turning tool.
          Blue Heeler
            @blueheeler
            Posted by Michael Gilligan on 03/03/2021 23:15:44:
            If I'm stuck on making a small crown and its kicking my **** to "produce a suitably dimensioned ball-turning tool" is probably going to kick my bruised **** out my shed door
            I need a much easier method than that, I'm close to getting some files out.
            Edited By JasonB on 04/03/2021 06:57:33
            Edited By JasonB on 04/03/2021 06:58:34
            #531544
            Pete.
              @pete-2
              Try planning it as series of cuts like a manually operated cnc process to get the profile, then blend it together with a file, Jason the moderator has some photos carrying out this process, I'm sure he'll explain in more detail when he sees your post.
              #531545
                Posted by Blue Heeler on 03/03/2021 23:29:29:
                You haven’t even mentioned what size the pulley is … but the ball-turning tool need not be much more than temporary tool-post on a pivoted lever.
                Blue Heeler
                  @blueheeler
                  Posted by Michael Gilligan on 03/03/2021 23:42:12:
                  Sorry Michael I should have been a lot more clearer mate.
                  I'm trying to make (in the end) a drive pulley out of brass approx 1" in diameter and 1" wide and bored for a 6mm shaft out of bar stock with just a gentle crown in the middle to take a small flat belt (its to drive a model steam accessory).
                  Chucked up the brass and thought it would be a super simple and quick job. Found out that it wasn't working out like that and stopped wasting brass and went to ali to try and work out how to do it.
                  Not sure if I'm just having a brain f**t here, but its got me stuffed.
                  Edited By JasonB on 04/03/2021 06:58:12
                  #531549
                  Blue Heeler
                    @blueheeler
                    Posted by Pete. on 03/03/2021 23:31:00:
                    Thanks Pete.
                    #531551
                      Posted by Blue Heeler on 03/03/2021 23:57:25:
                      I'm trying to make (in the end) a drive pulley out of brass approx 1" in diameter and 1" wide […]
                      At those proportions you will need your surface to be much bigger radius than the pulley, but the principle is still good … You might be pivoting the lever on the shed wall though, rather than clamping it to the lathe devil
                      Not really relevant, but here are some notes about the ‘crown height’ on full size pulleys.
                      http://www.visusa.com/belt_tracking_m01.htm
                      Edit: The first few seconds of this woodworking demo are probably all you need to understand what I am wittering on about : https://youtu.be/fmzD8wI8RIA
                      Edited By Michael Gilligan on 04/03/2021 00:30:36
                      #531552
                      Blue Heeler
                        @blueheeler
                        Thanks for the link Michael.
                        #531555
                        Blue Heeler
                          @blueheeler
                          Thanks all, managed it finally, that camber is 1.5° –
                          #531558
                            having spent enough time toning down the language used I not go through it again, if you search "crowning jasonB" on the homepage search box you will find several threads like this about crowning pulleys & flywheels and also fish bellies on conrods.
                            This has always been the traditional model engineers way of doing it so no need for large radius ball turning tools and you were right in your first post about getting your files out.
                            #531559
                            Nicholas Farr
                              @nicholasfarr14254
                              Hi MichaelG, I'm not really into wood turning, but a very interesting demo you've linked too. yes
                              Regards Nick.
                              #531566
                              not done it yet
                                @notdoneityet
                                If it’s for authenticity, OK. But for a normal flat belt I would stick to a pulley with side guides and make full use of the contact area. Worked well enough on our Massey Harris 701 baler.
                                #531570
                                Chris Evans 6
                                  @chrisevans6
                                  Faced with this type of calculation again do it in steps as suggested. The formula is the square root of radius squared minus distance moved (step over) squared. Hope this makes sense.
                                  #531575
                                    Posted by Chris Evans 6 on 04/03/2021 08:41:17:
                                    is that not just the radius?
                                    #531576
                                      Posted by Blue Heeler on 04/03/2021 05:49:05:
                                      That looks good yes
                                      Martin Kyte
                                        @martinkyte99762
                                        Hand turn it against a prifile guage.
                                        regards Martin
                                        #531581
                                          Posted by JasonB on 04/03/2021 08:49:48:
                                          … but you only emboldened part of the text !
                                          Try adding some mathematically relevant parentheses to what Chris wrote.
                                          ega
                                            @ega
                                            Posted by not done it yet on 04/03/2021 08:25:12:
                                            I seem to remember that the pre-war Austin 7 dynamo pulley was like this but also had a degree of crowning?
                                            Belt and braces!
                                            #531609
                                            Nigel McBurney 1
                                              @nigelmcburney1
                                              General practice with belt drives ,in our sphere of vintage steam and oil engine belt drives ,was if the motive power runs at a higher speed than driven machine ,the large pulley on the machine would be crowned and the small pulley on the engine would be parallel, where it was the other way round ie a traction engine driving a faster rotating small pulley on sat a threshing machine then the T/E flywheel would be crowned and the small pulley would be parallel and very often with raised sides to stop the belt slpping off as the threshing machine was never in perfect alignment as it was on rough ground, Now on oil engines as they very often ran faster than the driven machine the engine belt pulley was parallel and I have not come across any genuine manufacturers pulley that was crowned,with the exception where they had to drive a generator or thrashing machine and these would be vey large pulleys. Where it was common in steam practice for portable and traction engine to have crowned flywheels ,oil engines tended to have flat face flywheels only one of my oil/lgas engines has a crowned flywheel, So for a small pulley is crowning essential,?
                                              #531615
                                                Posted by JasonB on 04/03/2021 07:26:10:
                                                Fair point, Jason, but the truth is: There is no need for most of the things that are discussed on this forum.
                                                It’s a hobby, a pastime, an intellectual stimulation [or whatever]
                                                Suggestions [hints] were invited, and I made a suggestion.
                                                Personally, I am more interested in problem-solving than in following ‘the traditional model engineers way’.
                                                Blue Heeler
                                                  @blueheeler
                                                  Thanks for the link Jason
                                                  #531622
                                                  Douglas Johnston
                                                    @douglasjohnston98463
                                                    When I built a belt sander I faced the same problem and solved it by keeping the pulley parallel and then wrapping some insulating tape round the central third of the width to create the crown. Worked a treat and is still in use after 20 odd years.
                                                    Doug
                                                    #531628
                                                    Martin Kyte
                                                      @martinkyte99762
                                                      In general the 'traditional' or common way of doing things is the optimum. Methods that work and are reasonably simple get established as the norm until superceeded by something new like everyone having CNC lathes. Where 'Traditional' goes wrong is when a craft has stopped evolving (which Model Engineering hasn't) such as flint knapping for example. I'm sure you can think of other examples.
                                                      regards Martin
