For too many years, the longitudinal seam on domestic copper hot water cylinders has been welded using the MIG welding process. Initially the wire was 0.2% Si, 0.2%Mn, bal Cu. The shielding gas was argon.
Argon is expensive.
Replacing the Si and Mn with Ti and Al allowed the use of nitrogen as the shield gas – much cheaper. When we became the second UK supplier, the wire became more readily available to the industry, it was no longer rationed and we picked up a substantial volume of brazing alloy business.
However all the other joints tops, bottoms, and bosses are, I believe, still brazed. This is due, in part, that in order to cope with the increasing gap on a circular weld, the volume of filler that needed to be put down increased. This is at odds with a wire feed mechanism delivering wire at a constant rate.
Whilst at Johnson Matthey, we spent many hours trying to automate the brazing of copper cylinders using a wire feeder but all to no avail.
You can TIG a boiler, but MIG ……….?
Keith
