British machine tools
Home Forums General Questions British machine tools
Viewing 25 posts - 1 through 25 (of 103 total)
  • #23439
    Ian Parkin
      @ianparkin39383
      Ian Parkin
        @ianparkin39383
        My son in law was admiring my colchester student lathe and asked do we as a nation make any lathes now such as this?
        How much was a student lathe when it was new? and how much would a british made lathe be now
        Ian
        #159618
        john swift 1
          @johnswift1
          A good question not enough people ask
          just had a quick search and Boxford and BSA Machine Tools don't make it obvious on their websites
          ( boxford.co.uk and bsamachinetools.com )
          KWIL
            @kwil
            Dean, Smith and Grace for a start
            #159626
            NJH
              @njh
              Have a look HERE Ian.
              Hope you have deep pockets!
              Norman
              #159632
              thomas oliver 2
                @thomasoliver2
                In 1961 the price of the Boxford AUD Gearbox Lathe was £225. The BUD – no gearbox, was £200.
                A common misconception is that Myfords offered more accessories than Boxford. This was not the case and Boxfors offered excellent 40 accessories.
                #159639
                NJH
                  @njh
                  Thomas
                  By a quick and dirty calculation that would put the inflation corrected price of the AUD today at around £3900 disgust
                  Norman
                  #159642
                  Phil Whitley
                    @philwhitley94135
                    Colchester and harrison are now parts of the 600 group, and still make a range of lathes, http://www.600group.com/products/
                    #159643
                      I thought the 600 groups beds were cast and finished in the far east so maybe just British assembled.
                      J
                      Edited By JasonB on 03/08/2014 20:54:12
                      #159647
                        Just more than half the price of a Myford Connoisseur. An interesting comparison.
                        Ian Parkin
                          @ianparkin39383
                          So does anyone have any idea how much a new colchester lathe is or a dean smith and grace?
                          #159654
                            Ian,
                            There's a price-check link on this page.
                            … it appears to just send them an eMail
                            Lathejack
                              @lathejack
                              Our company bought a new Colchester Triumph 2500 variable speed lathe with 1500 between centres around five or six years ago. This is just a rebadged modern Harrison design and is made in China with a bit of work done in the UK.
                              It's not made to the same standard as the original Colchester machines and has some grubby detailing typically found on some budget Chinese machines. It arrived with a slightly misaligned bed gap piece, a few screws missing and the odd few bottomed out before they were tight. The plain bushes supporting the gearbox input shaft wore out prematurely, and just recently a very small selector fork in the gearbox broke and the headstock started lifting off the bed by a couple of millimetres after the rather small securing bolts came loose.
                              After the tiny bronze gear selector fork for the leadscrew and feedshaft reverse mechanism failed early on, the headstock cover was removed to check the internal condition. It was as clean as a whistle with no swarf or foundry sand inside, but a magnetic probe dipped inside pulled out an M6 cap screw and a 30mm diameter washer. The correct location for these inside the headstock was already occupied by identical items, so the fitter must have dropped them inside and simply fitted some more instead of fishing them out.
                              It is not used as a production machine but gets regular light to medium use. It does however, machine superbly and is as solid as a rock with an extremely hard bed. I cannot recall at the moment how much it cost, I will have to check.
                              The geared head lathes that have long been supplied by Boxford are unique to them and do not seem to be offered by anyone else, so maybe Boxford do make them, somewhere.
                              Some of the lathes offered by BSA Machine tools are quite good Far Eastern copies of the original Colchester lathe design from the 1970's, such as the Student 1800 and the larger models.
                              Edited By Lathejack on 03/08/2014 22:28:51
                              Edited By Lathejack on 03/08/2014 22:34:13
                              #159658
                              Bazyle
                                @bazyle
                                Since 1961 house price inflation has been around 200x (outside London), but cars maybe 10 fold (and much better quality). Average salary then was £1000 and petrol just 5p a litre. So the AUD was 25% of average salary. Now that would be £7.5k.
                                I think it is reasonable ot assume that a lathe should, like a car, benefit from improved industrial techniques so putting the AUD at about £2k or rather more than the imported equivalent. I think this might be possible in the UK if it weren't for the property value putting up the factory rent and wage inflation being 25x
                                Equiping schools with lathes must have cost a fortune back in the '60s when many were getting Boxfords and Colchesters. But actually that was probably weay less that the current requirements for computers in schools.
                                #159685
                                Saxalby
                                  @saxalby
                                  Re the price of Boxford lathes.
                                  I have the 2009 price list and for a Boxford model 280 (11" swing, 30" BC) it was £10,000 plus vat. So I guess its now about £13K.
                                  #159705
                                  Ian S C
                                    @iansc
                                    When I got my Taiwanese 1326BH lathe, I was told by the owner of the company I bought it off, who had just come back from the Taiwan factory, he found a great pile of lathe beds marked Colchester England in the yard behind the foundry, and the Taiwanese CEO said OH yes we make all there smaller lathe beds, they make the rest of it, same bed as the ones you are buying.  I think I paid around $NZ1100.
                                    Ian S C
                                    Edited By Ian S C on 04/08/2014 12:58:58
                                    #159718
                                    Stephen Benson
                                      @stephenbenson75261
                                      I have a Cowells and I believe they are the only wholly British made lathe available today my Lathe with a Newton tesla conversion **LINK**
                                      Cowells Website
                                      Ian Parkin
                                        @ianparkin39383
                                        So really in answer to my original question we dont actually completely make a single manual lathe in this country ?
                                        and even cnc or so lathes are made from far eastern castings
                                        Are new myfords made completely in the uk? if indeed there are any new ones (other than old stock)
                                        DSG are making 1 lathe for stock so they are hardly a big player for smaller lathes
                                        #159742
                                        Raymond Anderson
                                          @raymondanderson34407
                                          As far as the Harrisons are concerned , the manual ones are all made in the far east now, only the cnc ones are made in the uk.
                                          #159748
                                          Russell Eberhardt
                                            @russelleberhardt48058
                                            Posted by Ian Parkin on 04/08/2014 14:29:59:
                                            Come to that, are any manufactured products made completely in the UK? Like it or not we live in a global market and manufacturing companies that want to survive must buy their raw materials, components, and sub-assemblies on the world markets. The alternative is protectionism and decline.
                                            Russell.
                                            #159814
                                            Phil Whitley
                                              @philwhitley94135
                                              Not only that Russel, we are being trained to accept poor quality and generally a dumbed down experience of what things used to be like. Apart from machine tools, look at the audio people accept today as good, without exception, anyone under 30 used to listening to phone/player quality audio is blown away by the sound quality of my 1970's stereo system playing vinyl! It is all very sad, but the people who profit from industry can make more profit from cheaply made third world goods, made where there is no health and safety regs, and working conditions are poor, as long as we can be persuaded that the vastly reduced quality is " the very latest thing" and also that it is better than anything that came before it. I well remember a comment on one of these machinery sites made by a tech school instructor when someone noticed that his shop had two distinct areas containing different eras of machinery. He said " I start the new kids off on the crap modern machines made after 1970, and when the have made all their mistakes, I let them use the good stuff that was made before, that way I don't feel really bad if they crash a machine and wreck it"
                                              It is all very sad, as in a few generations, not only the machinery, but also the skills to use it could be lost, and this process is speeding up, it is very noticeable that almost anything you buy today to replace something made even ten years ago is of inferior quality, poorer performance, and more expensive. Things are marketed under "brands" that have no connection to the item, Since when did Caterpillar make power tools? of course, they don't, they are chinese sourced tools marketed under a brand that gives them a fake association with a name synonymous with a tough quality product. To see the names of Harrison and Colchester going down this route ( though perhaps not as far, yet) is sickening. Mind you think for a moment of the virtual immpossibility of getting any sort of foundry past the health and safety police nowadays and you begin to understand some of what is going on.
                                              Phil, East Yorkshire
                                              #159816
                                                I'm not sure I entirely agree with you Paul. yes I am horrified at the sound quality people accept from i-products, even compared to other phones, and despise the fact that most digital radio is mono(!) a lot of stuff from the far east is very good.
                                                My (Chinese made) Nikon digital bridge camera's photos knock spots off anything I was able to achieve with my old Pentax SP1000. I like my old Hameg scope, but I'd happily swap it for a new digital one.
                                                I've seen the difference between a cheap 'baby lathe' of old British manufacture (Super Adept by F.W. Portass) and new Chinese manufacture (C0 Bay by Seig). compared to average wages they are similar prices , but the Seig is streets ahead in every respect: finish, fit, accuracy.
                                                I'm not saying some British stuff isn't very good, but I think many tales of how bad imports are are often exaggerated. It's like judging the British car industry solely on the Morris Marina or the Austin Allegro.
                                                Russ B
                                                  @russb
                                                  Posted by Russell Eberhardt on 04/08/2014 18:04:12:
                                                  ………….The alternative is protectionism and decline.
                                                  Russell.
                                                  I agree completely and I've been spending a lot of time thinking about it, and I'm finding issues, not conclusions or solutions.
                                                  Doing any sort of trade in the UK…….
                                                  Consider fuel duty "A"
                                                  tax on premises (for storage perhaps) "B"
                                                  Energy prices "C"
                                                  overall tax "D"
                                                  Company 1 Buys stock and sell it to Company 2 – it accumulated A,B,C and D for them to get it and sell it.
                                                  Company 2 pay delivery to the courier (who has to pay A & B on his van and C on his storage, D overall)
                                                  Company 2 then pays B,C and D, to sell it to company 3 who then pay a courier……. etc. etc. around, and around – perhaps to the end user, who earn't his money from what little turnover company 1 made, who then had to pay tax on it as earning….
                                                  And why not consider, the cost of the machines that the stock or part was made on, which must be paid back – if that machine was also made under the same circumstances it's also going to have accumulated similar expense which will be pushed on to all it's "children" – the issue just compounds itself, again and again and again – where is all this money filtering too, and what the hell are "they"doing with it all?
                                                  How much did company 1, 2 or the courier actually get, the smart person would simply move company 1, 2, 3 and the courier to somewhere else in the world – problem halved or better?
                                                  every time you lift a cheek to fart in the UK someone either charges you money, you get taxed or you get fined – isn't it fun – I can see why other countries are better choices for manufacturing – and it runs far deeper than just labour rates.
                                                  no question marks! rant over laugh
                                                  Happy Tuesday!
                                                  Edited By Russ B on 05/08/2014 15:10:32
                                                  #159833
                                                  Jon Gibbs
                                                    @jongibbs59756
                                                    It's fun to generalize and be patriotic but it's pretty futile IMHO.
                                                    There are good and bad Far East manufacturers, as John S's recent visit to China showed, and we all know that there are good and bad British manufacturers. It will always be thus.
                                                    The only generalization I think we can legitimately make is that people are the same everywhere and as such; some are conscientious and some are rip-off merchants and some are corner cutters. It is independent of country.
                                                    Another generalization could be that marketing hype is and always has been the enemy of the consumer.
                                                    Jon
                                                    #159870
                                                    Russell Eberhardt
                                                      Posted by Phil Whitley on 05/08/2014 14:04:20:
                                                      I'm not so sure about the vinyl being better than CDs but the old loudspeakers such as my Rogers, knock spots of the modern miniature ones. It is a physical impossibility for a small speaker to give good results at reasonable volume. The large cone excursion required for bass notes gives non linearity distortion and phase shift intermodulation with higher notes due to the Doppler effect although there is some argument over the audibility of the latter.
                                                      Am I becoming a grumpy old man?
                                                      Russell.
                                                      Edited By Russell Eberhardt on 06/08/2014 11:29:59
