No bushing Nobby, just using fairly high speed keeps things on track.
I can get just over 6,000 RPM out of the Meddings, which if care is taken with the down-force, it gets the job done with very little attrition rate of the carbide drills, and besides, I am only drilling brass.
In reality, the drill should be turning at somewhere over 80,000 RPM to make it stable enough to drill thru almost anything with no support.
I have designed and almost completed an air pedestal drill that gets towards that speed, but I abandoned it after I was given the Meddings, as that copes well enough with what I want to do at this time. Why make life difficult for the sake of it?
The mag chuck on it make things so much easier to set the jigs up. Just use the correct sized blank in both the chuck and jig, press things down onto the table then turn on the chuck, everything lines up spot on, with no fiddling at all with clamps etc.
With regards to the surface grinder. Over the years, I have either made or picked up cheaply all sorts of fixtures to fit onto the mag chuck, so not only does it surface grind, I can resharpen almost all my tooling as well. The only thing I can’t do at this time is grind side flutes on milling cutters or reamers, but I am not worried, I will pick something up one day at the right price to do that.
This is now getting a bit far off topic, but hopefully, it may help someone along their journey.
