Posted by CHARLES lipscombe on 16/01/2017 22:05:17:
Whilst I more-or-less agree with Hopper about the need for precision, it seems that these tiny carburetters are very sensitive to jet size variation
Thanks everyone, Chas
Bear in mind too that most carbutator problems are electrical. I'd bet two rabbit traps to the old black billy that if you get your New Imperials' magnetos professionally rebuilt so you have a good strong, reliable spark, you will find the old bangers will run much better on any jet that is close enough.
I've seen it happen over and over again on vintage Harleys and various Brit bikes over the years. Weak spark will appear for all the world like fueling problems. You stop on the side of the road, change jets and presto, it runs better — because the maggie or the spark coil and the sparkplugs have cooled down. Then down the road it starts playing up again as the maggie or coil heats up so, hey, a bigger jet helped earlier, so lets stop and put the next bigger one in, and hey presto the bike runs better again — because the maggie or coil has cooled off again. Then next time they roll the bike out of the shed and start it up from cold — guess what, the jets are too big! Must be super sensitive to jet size! So down in jet size they go and all is good, until they get on the road and the maggie heats up … repeat, repeat, repeat etc.
New coil (if used) plug leads, caps and plugs are essential too. Seen many vintage riders come to grief trying to run the original equipment for authenticity but as the insulation breaks down, inevitably, over time dramas ensue. Most of those guys thought it was fueling problems too and spent massive time tinkering with carbs, cleaning gunge out of tanks, sealing manifolds etc etc only to find it all cleared up with a good ignition system. It took one old guy I know , a lifelong Harley expert, engineer, former beach racer etc, about 10 years to give up on the fuel system of his WLA and fit a new coil and leads. Guess what happened to his carb problems instantly?
Edited By Hopper on 16/01/2017 23:47:38
Edited By Hopper on 16/01/2017 23:54:59
