The original Plasplugs sharpening system, which included the drill sharpener, seems to have come off the market some time back. The small grinding wheels are still supplied as spare parts.
As I recall it the set price was in the £60 to £70 region in B&Q et al when the knock offs appeared at around £30. Presumably Plasplugs sales took a serious hit.
Replacement version had a poke the drill down a hole device which was, by all accounts, as hit and miss as any other cheap version of the breed. (I'm sure that sort would go much better if you could see what was going on where the drill bit hits the wheel.)
Looks as if nice and smart, lightly used, prices for second hand sets seem to be in the £30 – £45 region on E-Bay and Facebook Marketplace. Local free-ad papers and boot fairs (when they are permitted again) seem rather lower.
Mine is the original version in a cardboard box. No snazzy plastic case with transparent lid like the later issue.
The pivoting drill carrier assembly on mine has a metal bar to accurately set the height of the point when sharpening. Also the moulding behind the recess for the actual drill carrier is shaped so as to support the shank. Thus the drill shaft angle in relation to the vertical surface of the wheel is well defined. I imagine the relative positions of bar and moulding are quite critical if the drill point is to be the right shape. The drill carrier itself isn't terribly snug in its recess. Certainly not enough to resist grinding forces on its own.
This is probably one place where the knock offs fall down. Lacking shank support Robs Aldi one hasn't much chance as bought.
I'd be unsurprised to discover that the actual drill point projection set by the Vee gauge to be less than ideal on a knock off too.
The LiDL (Parkside) version looked well made but the grinding wheel provided was a spectacularly inefficient and not true running diamond plated sheet steel device. I suspect the critical dimensions may not have been sufficiently correct too. The actual plastic mouldings were rather better than the Pasplugs original, which isn't bad. Seemed a shame to got the trouble of a really good set of moulds yet not get the basic engineering right.
The trick when using the device is to lightly hold the drill down onto the bar and support so as to set it at exactly the right angle. I've usually done an equal number of swipes each side rather than keeping going until the drill swings freely with no grinding action or sparks.
Mine was generally used to quickly do one drill rather than get my eye in on the Picador jig. Now I have the Clarkson set up that is quicker than either.
Edited By Clive Foster on 31/10/2020 23:14:18
