Direct drive air compressors are noisy. Belt driven compressors are quieter, because the compressor runs at a lower speed. Diaphragm compressors are quietest of all, which is why Dentists use them to power their drills.
Mine are direct drive, one (Branded S I F) is claimed to have a 3hp motor, but starts and runs off a 13 Amp socket, without blowing the fuse.
Before putting it into use, I removed the plugs on the reservoir, and sprayed Waxoyl through it, to reduce the risk of rusting. (Catch 22? – NO, I used the HPC for this)
Another, the HPC with a smaller motor, capable of running off a 5 Amp supply, is still functioning happily after more than twenty years.
After use, I ALWAYS drain out the condensate, and leave the drain open. (Recommended by the supplier – a local compressed air equipment specialist). This means that the motors always start up on No Load, except when the pressure falls to the level where the pressure switch restarts the motor. The HPC has a valve on the compressor head to allow an unloaded start, even if the reservoir is pressurised.
At least, any moisture remaining after drain down has a chance to get away.
Don't be surprised if the drain stops after a while, and then restarts. (You are quite likely to see "steam" coming from the valve) As the air expands, it cools; often to the point where it freezes the condsensate. The big 200 Gallon (909 Litre) reservoir, in my bus garage, used to freeze repeatedly during drain down. We used to open the drain tap, and go for a cup of tea, while it spat lumps of ice around!
Both compressors have condensate filters fitted between between the outlet and the delivery connections for the flexible hoses. It is surprising how much water accumulates there during use, and needs to be drained out.
Must learn to check for typos BEFORE posting!
Edited By Howard Lewis on 08/04/2016 10:16:57
