38 Tpi thread
38 Tpi thread
Home Forums Beginners questions 38 Tpi thread
Viewing 19 posts - 1 through 19 (of 19 total)
  • #144037
    Clive Hartland
      @clivehartland94829
      Can someone help me please, I have a Metric ML10 and a full set of change wheels for metric and Imperial threads.
      I need to cut a 38Tpi thread for an eyepiece fit so can someone please calculate a gear cluster for me.
      Clive
      Clive Hartland
        @clivehartland94829
        #144039
        Les Jones 1
          @lesjones1
          Hi Clive,
          I do not know what the full set of change wheels for an ML10 consists of. If you can list the number of teeth on the change wheels, the number of teeth on the fixed gear on the spindle and the TPI of the leadscrew I will have a go at working out a working out a way to do it. I also have a program I found on the web some time ago but I can't remember where. If you PM me with an email address I will send you a copy of the program.
          Les.
          #144053
          Bazyle
            @bazyle
            On Duncans metal pages he has programs for gear calculating.
            #144054
            Roderick Jenkins
              @roderickjenkins93242
              Clive,
              Assuming a basic set of wheels from 25 to 65 in 5s plus a 63 I get:
              Drivers 25, 35, 50 and drivens 55, 60, 63 on an 8tpi leadscrew giving 38.016 tpi
              Does the the metric ML10 have an 8tpi leadscrew like the metric 7 series?
              I've written an EXCEL spreadsheet for calculating threads. PM me if you'd like a copy
              cheers,
              Rod
              #144064
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Hi Clive ,
                38 tpi is o,668 mm pitch or very nearly o,667 mm .
                Think of it as 2/3 of 1 mm pitch and do all gear calcs directly in mm .
                Regards ,
                Michael Williams .
                #144079
                Les Jones 1
                  @lesjones1
                  Hi Clive,
                  I've found the website for the screwcutting calculator I mentioned in my last post. The program I was referring to was "nthreadp.exe" and there is another one that looks very similar "boxfthreadp.exe"
                  They are on this website.
                  Les.
                  #144089
                  Clive Hartland
                    @clivehartland94829
                    I have been unable to get into the workshop at the moment so will come back in a couple of hours and let you know how I get on. Thank you for the details so far.
                    A point here is that the optical inst. makers always seem to use odd pitches and threads, we have boxes of them but not this 38tpi one.
                    Clive
                    #144104
                      Clive,
                      Just a thought … 4 BA has a pitch of 38.46 tpi, which is pretty close.
                      Maybe the threads were originally chased ?
                      Edit: Sorry … pitch is the wrong word there blush
                      Here is nother useful reference
                      Edited By Michael Gilligan on 16/02/2014 13:36:39
                      #144113
                        As a rather pleasing digression, I just found this description of a Karger "Sliding Spindle" lathe.
                        … I don't think my father ever had that luxury, but I do remember him hand-chasing threads on brass tube in the early 1960's.
                        Edited By Michael Gilligan on 16/02/2014 17:00:17
                        #144122
                        pierre ehly 2
                          @pierreehly2
                          Cleeve,
                          Harold hall site
                          http://homews.co.uk/page30.html
                          brgds
                          pierre
                          #144126
                          MICHAEL WILLIAMS
                            Optical threads might have origin in the Lowenherz thread system .
                            This delightfully oddball thread system was used for a lot of early scientific equipment .
                            Originally a seemingly quite random collection of sizes and pitches but later got tidied up a bit .
                            Michael Williams .
                            #144146
                            Clive Hartland
                              @clivehartland94829
                              Michael, My bro. has a Schaublin(old) with the sliding spindle and the brass thread quadrants. I have used it and chase the threads very slowly. It does have a tendency to 'jump' threads occasionally.
                              All OK now with the 38tpi, cut and done with a chaser from a friend. All I have to do now is take it into work and see if it fits.
                              Clive
                              #144148
                                Well done, Clive
                                As a matter of curiosity … whose manufacture is the eyepiece?
                                Clive Hartland
                                  @clivehartland94829
                                  Hello Michael, The telescope is of Hilger and Watts name so is very old but is perfect for our target system as it has a Pentag prism on the OG.
                                  Clive
                                  #144157
                                    Thanks Clive
                                    Beautifully made equipment …
                                    My wife recently treated me to an old Watts Theodolite [pre Hilger] … The reticules are a bit grubby, but the build quality is awesome.
                                    Brian Wood
                                      @brianwood45127
                                      Hello Michael,
                                      Having made a recent study of obscure threads, including Lowenherz, 38 tpi at 0.668 mm pitch falls between the two Lowenherz sizes of 0.60 mm and 0.70 mm; 4BA at 0.660 mm pitch was actually the best match being only a few microns out.
                                      The thread angle for the series was 53 degrees 8 minutes.
                                      Brian
                                      #144230
                                      Clive Hartland
                                        @clivehartland94829
                                        I went through the box of chasers and taps and dies from the old stuff, I found chasers of 31 and 41 tpi. Also lots of odd tpi, even a 23 tpi. I have no idea where or what they were used for. Some of the taps have no markings but seem well used so maybe production tools. I think I may well take the box of chasers and any that I can identify from the taps and dies. I have no idea what I will use them on! Also found a box of taps and dies of whit. form down to 1/16", it seemed very coarse for the dia. It seems this stuff was stored many years back and as workers retired the knowledge is lost so they become useless, that is until I uncover them !
                                        Clive
                                        #144234
                                          Posted by Clive Hartland on 17/02/2014 15:02:42:
                                          … It seems this stuff was stored many years back and as workers retired the knowledge is lost so they become useless, that is until I uncover them !
                                          Keep up the Good Work, Clive
                                          You might find this listing useful for quick reference.
