Reply To: Eccentricity / Run-Out
Home Forums The Tea Room Eccentricity / Run-Out Reply To: Eccentricity / Run-Out
#320547
    Posted by An Other on 07/10/2017 18:56:34:
    Interesting thread – We had a Bosch machine which we eventually dumped because one arm of the (apparently monkey-metal) drum support spider broke, resulting in various graunching noises. This was replaced with a Whirlpool machine, but now we seem to have another problem. I don't want to hijack the thread, but has anyone anything to say about the economy of washing machines.
    Both the Bosch and the Whirlpool were supposed to be 'economic', but both use(d) large amounts of water. (we have our own deep freshwater well, so I can easily keep track of what we use – we have to keep an eye on it because it is possible to pump it dry under some circumstances).
    The Whirlpool machine is terrible – we use what is supposed to be the most economic (in terms of water use) cycle, and by my measurements, the thing uses about 400 litres of water for one wash – both machines seem to have multiple rinse/dry cycles, which seems to be where the water is going. It is not easy to actually decide what is going on – there is no external indicator showing 'current function' in detail, the instruction manuals are useless, so the only way is to sit and watch the damn thing – and it still isn't obvious – life is far too short for that.
    I did suspect at one point that the supply pressure was too low, but our water pressure is regulated to 6 bar, and easily maintains that. Apparently most European countries supplies should operate at between 4 to 6 bar, so I don't think that is a factor.
    I have read about machines using bubble technology (as opposed to simply swilling water in), but I haven't (yet) found any info on these machines. We want to junk the crap we have now, and since we have to buy another, I want to get a machine which does operate economically, both electricity and water, as opposed to the incredible stuff the advertisements claim.
    Funnily enough I found the manual for our Swan SW4010W the other day.
    Efficiency rating A+++
    Cotton 60C 8kg load, 1400rpm is 0.93 kwh and 54 litres, 228 minutes.
    40C, 4kg load is 0.75kwh and 45 litres, 222 minutes.
    Off mode power consumption is 0.5W, on mode 1W.
    Washing 59 dB, spinning 76/78 dB ()depending on speed).
    Washes really well, is actually easy to understand – choose program than change temperature if you want.
    As you can see the downside of excellent performance is long cycles!
    I thought that's impressive for a <£200 machine!
