It's only taken a couple of years, but I've finally made some fittings for my verical boiler (to the design in Tubal Cains Simple Steam Engines 2, but a little bit taller). My pressure gauge is one of a fire extinguisher, modified by removing a ring which increased its resitance – recalibrated against a quality gauge it works well.
Anyway, I filled it yup, turned on the gas and started heating. At 10psi the gauge leaked wisps of steam around teh base, a quarter turn stopped that. At 15 psi safety valve started to leak a little steam. I had it set fairly loose, and I was concerned that by 20psi it still hadn't popped.
I gingerly prodded the top pin of the safety valve to see if it was stuck and 'wham' a huge jet of wet steam hit the ceiling of my workshop, presumably as it primed. I lost 1/4" of water in the glass but it stopped wjhen I turned the gas off. A repeat outside saw the same., except teh geyser was about 12 feet high and created a localised shower downwind, much to the cat's alarm. It didn't close again until the pressure was nearly zero.
It's a Martin Evans pattern safety valve, and I think the problem is the fit of the valve stem in the screwed and vented plug at the top of the valve, although it has a good polished finish.
At least I know the valve can vent plenty of steam, but any advice on getting a proper 'pop' action?
