A while back I bought an Mt3 ER2 collet chuck from eBay which I've not used much until recently.
Whilst turning some 12mm silver steel I noticed a wobble and checked it out.
I found the body of the chuck had a wobble of 0.06mm and that amounted to 0.6mm at around 200mm from the chuck face.
I looked around at alternatives from reputable UK manufacturers and found them to be around 3 times the price.
So I thought I'd have a punt and hope that mine was a Friday afternoon job and bought another one.
Guess what?
This one had a relatively small wobble, though it took the form of a depression around 45 degrees of rotation with the rest being pretty solid.
I measured both chucks again, this time with a 16mm test bar. Chuck number one showed a wobble of 0.36 mm 40mm from the chuck face (110mm from the spindle face) and number two was much better (!) at around 0.15 mm.
I put a test bar in the taper and measured wobble at the same place relative to the spindle face (110mm out). This showed more or less no deviation (under 0.01mm) except for a tick which probably a defect in the test bar (which I regret to say has managed to rust).
I also tried turning the chuck in the spindle and that established that the error was in the chuck not the spindle.
So I expect the advice from the assembled will amount to, 'if you buy cheap, you get sh*t', which seems correct. But what should I expect? ANd what do I need to pay to get a decent quality?
And is it likely that the collets are the problem rather than the chucks?
Many thanks
Iain
