Boxford Lathe Big Bore Conversion
Home Forums Manual machine tools Boxford Lathe Big Bore Conversion
Viewing 25 posts - 1 through 25 (of 64 total)
  • #311512
    Brian Moss
      @brianmoss64697
      Does anyone know if the commonly encountered Boxford lathes can be modified to increase the spindle bore from 0.75" to, say, 1" or even more?
      I know that some of the later ones such as the VSL could be had with 38mm bores or thereabouts.
      #13027
      Brian Moss
        @brianmoss64697
        Big bore conversion?
        #311518
        David Standing 1
          @davidstanding1
          The X10 series Boxfords (250,280,330, 10.20, 11.30 etc) have a 35mm bore spindle.
          Would it be too forward of me to mention that my 280 is for sale in the classifieds?! blush
          #311519
          Clive Brown 1
            @clivebrown1
            The OD of the extreme end of the spindle on my ME10 measures 1.050", That measurement is also the tooth root diameter of the gear machined on the end of the spindle.
            A 1" bore wouldn't leave much metal there.
            Can't say how close you would get to the bearing inner races though.
            #311529
            Oldiron
              @oldiron
              I have asked Boxford this question and they said "Its not recommended to increase the bore of the spindle". I can measure a spindle from an "A" tomorrow and see how much wall there is. Cannot remember from my last foray into this subject.
              #311535
              Nick_G
                @nick_g
                If it was a good idea then I presume Boxford would have done it themselves as a bigger bore is always a good selling point.
                Nick
                #311536
                Clive Brown 1
                  @clivebrown1
                  Further to my post above, a bit of googling suggests that the ID of the bearings is 35mm, or 1,379".
                  leaving about 0.188" for a 1" bore. A bit thin I'd think.
                  #311791
                  Brian Moss
                    @brianmoss64697
                    Many thanks for all replies to my question. It looks as though there is no easy answer without a major rework.
                    #311797
                      Since the Boxford is a modular construction the bed runs right through under the headstock. Therefore you could make a new headstock from plate even a DIY aluminium casting, and fit it to the main part of the bed. Then line bore for your new selection of bearings. Moving it over to the headstock position should retain the alignment (assuming good condition bed). Probably worth basing it around the spindle of a 10" far eastern design if you can find one that has spares available. Would be an interesting article on MEW.
                      #311804
                      Brian Moss
                        @brianmoss64697
                        Thanks for your very interesting suggestion Bazyle, I did wonder about doing something like this. I'm not too familiar with Boxfords but would it be possible to do something similar by obtaining a spare headstock and boring it out to take larger taper roller bearings and either obtain or make a suitably larger spindle. If suitable roller bearings are not obtainable would plain bearings be OK ? Could the bull gear and pulleys be bored larger to suit the fatter spindle?
                        #311838
                        Niels Abildgaard
                          @nielsabildgaard33719
                          Been there,started but gave up.
                          Parts were to heavy for my old and wellworn back and the lathe where spindle comes from is cheap
                          https://www.hbm-machines.com/producten/metaalbewerking/metaaldraaibanken/metaaldraaibankensub/hbm-290-vario-metaaldraaibank
                          Edited By Niels Abildgaard on 13/08/2017 18:57:21
                          #311856
                            If you have a one off, or occasional need for the larger bore then it might be better to find an evening class or club with the bigger machine. If it is more frequent then it is probably better to get the bigger lathe anyway. Although Niels may have some more info I'd be surprised if the basic headstock would have sufficient extra metal around to bore out.
                            #311909
                            Niels Abildgaard
                              There is lots of metal to bore:
                              The original front bearing is 76.2 mm dia and the new proposed is 90mm.
                              #311913
                              John Stevenson 1
                                @johnstevenson1
                                Quite where it all fits in I’m not sure how to do it but my Orac has a completely new version of the headstock with D1-3 fitting
                                #312018
                                Brian Moss
                                  @brianmoss64697
                                  Thank you Niels for your link to the Far Eastern lathes. I think the one which would suit me is similar to a Warco WM280V here in the UK, but the price is almost £3000 which unfortunately I am unable to afford. Anyway, I do enjoy a challenge and would like to further examine the modified Boxford idea. What bearing did you have in mind for the bored out headstock with an O.D. of 90mm? And which spindle would be available ?
                                  #312026
                                    Brian, Neils was directing you to the lathe that the larger spindle was sourced from as a spare part not suggesting you buy a whole lathe. Though the same 290 lathes are available with D1-4 mount which would be even better than flange mount.
                                    If you wanted to stick with 1" bore then the 280 spindle would do and I think my bearings for that are about 70mm OD
                                    Edited By JasonB on 14/08/2017 19:37:21
                                    #312038
                                    Niels Abildgaard
                                      Hello Brian
                                      I bougth the spare chinese spindle plus unused bearings and a used Boxford headstock.
                                      I have sawed the rear part of headstock away because I need no back gearing.My present backgear is only used for unscrewing chucks.
                                      Putting headstock on saw made me realise that I was to old for lifting things.
                                      I then realised that I could have a complete new lathe from Holland for 2400€.
                                      I will stick with my much improved Boxford.
                                      You can have the parts for postage and a  gift to a dogs home
                                      Edited By Niels Abildgaard on 14/08/2017 20:54:03
                                      Edited By Niels Abildgaard on 14/08/2017 20:54:50
                                      #312048
                                        I have sent you a P.M.
                                        Brian Moss
                                          @brianmoss64697
                                          Niels, I have sent you a p.m.
                                          Brian
                                          #312071
                                          Brian Moss
                                            @brianmoss64697
                                            I should have referred to the Warco 290V in my earlier post and not the 280V; a slip of my typing fingers I'm afraid!
                                            Brian
                                            #312072
                                              Another possibility might be to take a look at the Australian made Hercus lathes, which like the Boxford, I believe, are a clone of the American South Bend 9" lathe. Hercus made a model called the 260 where they took the basic model and fitted it with a larger spindle supported in a larger headstock that sat the spindle an inch or so higher than the standard 9" lathe. Tailstock and topslide were fitted with thicker bases to match.
                                              If they are all based on the South Bend dimensions, a Hercus headstock and spindle should fit your Boxford. If you google around there are plenty of Hercus parts available still. Here's a brand new headstock complete with gears etc and spindle for A$485. **LINK**
                                              The fellow who runs the linked business is quite helpful and may be able to tell you if the 260 spindle and bearings could be fitted to a modified 9" headstock.
                                              Edited By Hopper on 15/08/2017 00:16:54
                                              Edited By Hopper on 15/08/2017 00:18:30
                                              #312101
                                              Niels Abildgaard
                                                Some pictures of parts for a proposed unification of modern chinese and obsolete british lathe parts.
                                                The bearing distance will need some headschratching.
                                                Edited By Niels Abildgaard on 15/08/2017 09:44:42
                                                Edited By Niels Abildgaard on 15/08/2017 09:45:10
                                                Edited By Niels Abildgaard on 15/08/2017 09:45:47
                                                #312103
                                                  Brian as you say you only want 1" bore then rather than use the large 290 spindle like Neils if you could get hold of the spindle from a 280 then there would be very little machining required as that uses 38009 bearings which are 75mm OD x 45mm ID x 21mm W. so you would not have to machine the bearing dia just make a couple of thin shells to make up the difference.
                                                  Edited By JasonB on 15/08/2017 09:57:51
                                                  #312126
                                                  Niels Abildgaard
                                                    Hello Brian
                                                    The post from Jason is very interesting and I want to delay my offer for sending headstock and spindle (that is clearly to big) for a feasibillity study.
                                                    It will be interesting for quite some if Boxford can be improved to one inch without having to rebore bearing holes.
                                                    There was another gentleman here from UK that had a spare headstock that he was willing to sell.
                                                    The Boxford standard Bearing holes are 76.2mm and 72mm.
                                                    Boxford spindle is 38.1 and 35 mm diameter bearing seats.
                                                    Can we on behalf of the waiting Boxforders ask Jason to measure or estimate the main length dimensions of his Spindle?
                                                    #312128
                                                    Niels Abildgaard
                                                      Posted by JasonB on 15/08/2017 09:56:43:
                                                      Hello Jason
                                                      Do You have a link to the spare parts list and drawing?
