Hi Andrew
From an earlier post, this may help you with insert selection.
Different tip radius, last 2 numbers in the code. 02=.2mm, 04=,4mm and so on.
First letter denotes insert shape, C=80deg Rhombic, D&K=55deg, R=Round, S=Square, T= Triangular, V=35deg.
Second letter denotes clearance angle. B=5deg, C=7deg, E=20deg, N=0deg, P=11deg.
Third letter denotes tolerances on thicknes and inscribed circle size, M denotes +or- 0,13mm for thickness.
Fourth letter denotes type, A,N,Q & W are flat top, G,M & T tops are shaped to provide cutting clearance and chip breaker.
First 2 numbers denote cutting edge length, 06=6mm on C shape insert, 07=7mm on D shape insert.
Next 2 numbers are insert thickness, 02=2.38mm, 03=3.18mm, T3=3.97mm, 04=4.76mm
Next 2 numbers are for nose radius, 02=0,20mm, 04=0,40mm, 08=0,80mm, 12=1.20mm.
The ISO codes sometimes have additional info such as PF for finishing or PR for roughing.
Emgee
