Long power cuts are a problem because many UK homes are almost 100% dependent on electricity:
- Gas central heating needs electricity for the controller, pump and diverter valves.
- Hands free telephones need electricity for the base station
- Cookers, fridge/freezers, Immersion heaters, microwave, kettles, electric heating systems and lights all fail.
- Many battery powered devices use secondary batteries that need to be recharged with mains electricity
- Connecting to the internet needs a mains powered router.
- DAB Radios are usually run on mains because they tend to eat batteries.
- etc, etc!
Power cuts are particularly problematic in cold weather for the infirm who cannot warm up by moving about or are on blood thinning medication.
My Storm Eunice power-cut started at 11:45 and lasted 8 hours. Didn't bother breaking out my emergency camping stove and light. I read a book until it got too gloomy at about 16:30, then ate a cold collation and went to bed. Not too cold because Eunice wasn't a below zero storm. I slept until the power came back on and set off all the local burglar alarms. Dithered a bit about getting up and went back to sleep instead!
My cave-man response was OK for an 8 hour cut, but it's made me think about next time!
Bad weather more often is a consequence of Climate Change, which is why the world is seeing record breaking and severe weather events in quick succession. The UK sets standards for construction and emergency response on the basis of 1 severe weather event per century. This risk based approach allows, for example, houses to be built on a flood plain provided the countermeasures will, on average, work 99 years out of 100. All infrastructure projects take this risk based approach and the likelihood and impact of storm damage is calculated from historic weather data. Big problem! Climate change means historic data can't be trusted to predict the future will be like the past. Climate change is causing once in a century events every decade or less. The theory suggests the effect will get worse and so far the evidence is tracking the theory, not the wishful thinking of climate change deniers.
Given the risk of being effected by flood, wind, snow, and extreme cold or heat is rising, I think I need to up my game. Flood is unlikely at Duffer Towers, but storm winds over 90mph are likely to remove tiles. Over 100mpg could remove the whole roof! The only answer to cataclysmic damage is to evacuate. I should be OK assuming family with 30 miles aren't also homeless, but I ought to make sure the house insurance and other important information (like bank passwords!), are safe and handy for an emergency exit! Perhaps spare pants and a toothbrush. (Note to Americans – pants are underclothes! The outer garment are trousers. )
Managing a long power cut is more difficult, especially if you can't drive outside the crisis area. My local supermarkets all depend on electricity and communications to run the freezers, lighting, tills, and computer system that does restocking. So does the village shop. I would have to rely on the Nanny State to ship in food, water, medicines and other essentials.
Short term cooking and light is easy enough : camping equipment! Heating is harder, I have no fireplaces. Radio news yesterday mentioned several house fires caused by folk running barbecues and candles indoors. Gas and paraffin heaters have always been a fire and monoxide poisoning hazard, so engage brain before using. Can the heater be knocked over, is it safe to run unattended, and where do the fumes go?
For me the jury is out on standby batteries and/or an emergency generator. Batteries go flat! Ideally, a generator should connect to the mains and power the whole house as normal, but this is tricky to do safely. The alternative is a temporary chain of sockets into which lights and essential appliances can be plugged. At the moment there's no easy way of me connecting to an outside generator in cold weather, or setting one up in the middle of a storm.
Needs more thought. Time to apply the British Army's 7Ps rule: 'Proper Prior Planning Prevents Piss Poor Performance'. Or maybe I'll cross my fingers and hope the disaster happens to someone else!
