Thanks to all for the suggestions re wicks – I will follow them up.
I did try a very little experiment using some wire wool – finest grade – stuffed into a short length of 15mm pipe (I did say it was a very small experiment!) which had the bottom blocked off. It worked quite well, got a decent flame, surprisingly hot, using the French version of meths – no blue colour and very cheap, buy it in the supermarket – the wire wool didn't seem to burn, well nothing to worry about anyway, and it all gave me encouragement to try something bigger and better. Things like how hard the wool is rammed in and how much the wick stands proud of the top are things to think about, plus air supply and of course, control.
Spirit cookers for boats use a similar wick based container too, but a very broad container, not very high containing just over a litre of spirit, with a flat wick across the top with a quite large gapped mesh across the top. Can't remember sizes, but is the container is say 8" in diameter and about 1.5" high then the hole i the middle for the flame is only about 2" diameter. The wick does not stand proud and the cookers produce a fair bit of heat. Control is by a cover that can be slid across the top from fully open to completely shut.
Ah Ian, Lyttelton, that was a lovely port when I was there, so quiet, peaceful and beautiful unspoilt scenery!
Chris
Edited By ChrisH on 04/10/2013 19:18:37
Edited By ChrisH on 04/10/2013 19:21:28
Edited By ChrisH on 04/10/2013 19:23:51
