On Tuesday I ordered a new vice and some 000 toolholders from ARC. Today they arrived, despite dire warnings of long delivery on the website. Thank you, Ketan.
The toolholders are an embarrassment. I confessed in another post that I ordered the wrong sort from China. I don't know if ARC have dropped the price or just that I'm an idiot, but Ketan's are barely more expensive than the cheap chinese ones. And of course they are the right sort, if not I can return them without a mortgage and they arrived in 1/10th the time. Moron.
I took advice here on the vice to buy and it was hard NOT to buy the ARC Versatile milling vice. I opted for the 5 inch, which is, well, solid.
and
The little one isn't quite sure if it should snuggle up to it's (very) big brother or creep quietly away before it's beaten up!
I have one tiny problem/question.
There's block you can screw on the underside which fits perfectly into the middle slot. 14mm and it is spot on. Should make taking the vice on and off very easy and avoid having to clock the vice in.
However, (and you knew there was a however), there's about 0.1mm difference across the width of the jaw. I've clocked the slot and there is around 0.02mm difference in the same area.
So I have two questions:-
1) Is this reasonable? Frankly, I would have been delighted to get this accuracy with a vice aligned by tapping, however, this is a step up so perhaps I should expect better?
2) if it's reasonable to look to a better alignment against the keyway, is there any sensible way of tuning this?
By the way, you can see I've taken the rotary base off. That would be one way of getting 'perfect' alignment, but I don't see a particular value in the swivel aspect of the vice.
And, this is not a complaint. I've done a bit of milling with this and I can already see that this vice is going to make a lot of things a great deal easier!
Iain
