Slightly off topic
The Alcosa blower on my forge was 1940's with a wall mounted rheostat . 240 ac .On the first stud it would the motor would turn really slowly ,just enough to keep the fire alight at lunchtime, and flat out on the 5th stud, would scream and blow coke out the fire and across the forge floor ..The motor had brushes .. What was regulated , the amps or volts ? The motor bearings died in the end , and i flogged the rheostat on ebay for £££ ! It gave sterling service for 70 +years used daily
The current fanset i use is constant speed with a slide air regulator ..the type with a cap , so i couldn't use the old rheostat ..
Now… These brush motors on variable speed angle grinders and routers… they go down to zilch rpm's too ..if i grafted one onto the fanset , would it run week in week out like my old one but using the built in electronic speed control?
Edited By Hacksaw on 23/01/2018 18:25:42
