Acme thread
Acme thread
Viewing 25 posts - 1 through 25 (of 83 total)
  • #249065
    dave george 1
      @davegeorge1
      Anyone around the burnley,lancashire area could knock me up a length of acme threaded bar,the thread im need is either 5/16″ or 3/8″ x 8TPI. im willing to pay for their services
      Thanks for looking
      dave george 1
        @davegeorge1
        #249147
          8 tpi is pretty coarse for a 3/8" diameter thread, it might be a bit of a struggle. At 1/16" thread depth plus clearance that only leaves less than 1/4" core diameter. It will probably need to be thread milled, even if you put the clearance on the nut instead of the core diameter.
          Can you get away with a finer pitch or greater diameter?
          not done it yet
            @notdoneityet
            Tell us more. Length, length of thread, material, why ACME, etc?
            Dies are available for purchase (recommend them for finishing a roughed/part formed turned thread). Square threads are often substituted for ACME threads. Do you need a new nut?
            HPC Gears can supply a range of items at reasonable(?) prices.
            #249158
            dave george 1
              @davegeorge1
              im after a cross slide feedscrew making,for a new cross slide that im getting made,length of cross
              slide is 10",and its looking at a 3/8" x 8tpi thread,got to be acme as that was the old feedscrew was
              also i dont need the nut as that is in the carridge/apron where the screw will go thru,
              i did try a few places and got quoted stoopid prices, 65 quid,50 quid,160 quid, for a 270mm length (this is going off a myford ml7 long cross slide feedscrew)
              #249187
              not done it yet
                @notdoneityet
                It would seem to be a sensible suggestion that the maker of your cross slide supplies the screw?
                #249192
                dave george 1
                  @davegeorge1
                  http://www.model-engineer.co.uk/forums/postings.asp?th=119194
                  I am getting a casting made local,im gonna do the milling of the t slots and dovetails myself
                  #249194
                    Posted by Neil Wyatt on 02/08/2016 21:22:18:
                    8 tpi is pretty coarse for a 3/8" diameter thread …
                    Agreed … Which is probably why the suppliers list such leadscrews in 'Stub Acme'
                    http://www.roton.com/Engineering_Data.aspx?line=Acme
                    Dave: I suggest you check the dimensions of the original thread carefully, before shopping.
                    Edited By Michael Gilligan on 03/08/2016 10:25:22
                    Edited By Michael Gilligan on 03/08/2016 10:26:42
                    #249196
                    Jon Gibbs
                      @jongibbs59756
                      Posted by dave george 1 on 02/08/2016 22:44:26:
                      Hi David,
                      Just to be sure that you're aware, an imperial ML7 cross slide feedscrew is 10 TPI (100 thou per revolution) and not 8TPI.
                      They're clearly no bargain but are available new, direct from Myford here… **LINK**
                      Jon
                      #249206
                      Hopper
                        @hopper
                        You probably should shop around for some Acme threaded rod. I am sure there has been discussion on here before and a UK industrial supplier was found to be quite reasonably priced. Can't remember the name though. But a forum search for "acme threaded rod" or something might turn it up.
                        Just for example, and I presume it's wrong side of the pond for you, but McMaster Carr sells 1ft lenghts for not much over $10. See link
                        dave george 1
                          @davegeorge1
                          Just an update.. i took the old feed scree to an engineer and he said its 3/8″ x 8tpi square thread and not a acme thread. He said a acme thread has a slight slope from the top to the bottom where as mine is straight
                          #249265
                            Posted by dave george 1 on 03/08/2016 16:20:44:
                            Quite so, Dave
                            https://goo.gl/images/9drHAr
                            mark costello 1
                              @markcostello1
                              Does not make it any easier.
                              #249292
                                Posted by mark costello 1 on 03/08/2016 18:54:46:
                                No … But it does save making the wrong thing. crying 2
                                dave george 1
                                  @davegeorge1
                                  I got to find someone to make this 😨
                                  #249299
                                  John Stevenson 1
                                    @johnstevenson1
                                    Just a suggestion but why not buy a S/H but decent Myford cross slide screw and nut and adapt it ?
                                    #249357
                                    Hopper
                                      @hopper
                                      You have a lathe. Make one. Lock the cross slide in position and set the topslide at 90 degrees to the lathe axis and use it to feed the cut in. A moving steady will probably be required, but is easy enough to make up too.
                                      #249383
                                      dave george 1
                                        @davegeorge1
                                        Yes i have a lathe but its still in restoration mode not been built back up yet
                                        #249394
                                        duncan webster 1
                                          @duncanwebster1
                                          +1 for Hopper's method. Square thread is easier to screwcut than ACME anyway, the tool tip is only 1/16" wide, so if the lathe will part off it will cut this thread
                                          #249403
                                            On such a small diameter an 8tpi thread will require the tool to be at a roughly 19-20 degree angle to stop it fouling the sides of the thread.
                                            Rather than a parting tool grind a cutter on the end of some round HSS, then rotate it to match the helix angle.
                                            John P
                                              @johnp77052
                                              Neil was right at the start of this thread by suggesting that
                                              this leadscrew would be best milled.
                                              The recently published articles in MEW 241 to 243 show
                                              how easily this is done.
                                              Some editing at the end of the article left out an important
                                              aspect of this operation.
                                              The reasons for the editing are not an issue as i could
                                              probably understand why this may have been done ,the
                                              missing text is as follows.
                                              "when cutting the second of these screws i was not even in the workshop ,i
                                              was in my elderly neighbours (older than me) garden trimming up some
                                              bushes,i doubt that there are many that can claim to have made an acme
                                              screw and done some gardening at the same time ".
                                              Of the five leadscrews that were produced and shown in the article i was only
                                              present while the first one was made .
                                              I was shopping in Asda when cutting this 3/8 by 10 tpi seen here in this photo
                                              in the album leadscrew.
                                              Conventional screwcutting these sort of leadscrews is a redundant operation and
                                              a complete waste of time.
                                              The unit as seen will fit on a Myford 7.
                                              John Stevenson 1
                                                @johnstevenson1
                                                Quote:
                                                The recent published articles show how easily this can be done. End quote
                                                Sorry John but I disagree. OK if you have already spent 3 weeks building the attachment and have all the skills but the OP has stated he doesn’t have a working lathe and from the tone, possibly not the skills either.
                                                TBH I don’t think the OP actually knows what he wants. He stated in his first post he wants a length of 5/16″ or 3/8″, then later says it has to fit a tapped nut in the saddle.
                                                Now it’s a very tall order to get anyone to make a thread to fit a worn nut you don’t have.
                                                No mention of end machining has been mentioned hence my suggestion to use an existing Myford screws and nut and make it fit
                                                Edited By John Stevenson on 05/08/2016 10:55:02
                                                #249610
                                                Roger Head
                                                  @rogerhead16992
                                                  Apologies if I've missed it, but so far it seems nobody has mentioned that it will need to be a left-hand thread, for a conventional cross-slide operation. In principle it doesn't make any difference, but spending money to buy tooling/pay-someone-to-make/whatever, and then finding that it operates in reverse, would really tee me right off.
                                                  Roger
                                                  Edit: I see that it is to fit an existing nut. So a conventional RH thread wouldn't even mate, never mind about it operating with the wrong sense.
                                                  Edited By Roger Head on 06/08/2016 03:01:47
                                                  #249613
                                                    Posted by Roger Head on 06/08/2016 02:43:09:
                                                    Roger,
                                                    Reading between the lines, I'm pretty sure that the screw is for a Grayson lathe, and that the cross-slide operation is rather like a Myford. [although 8tpi not 10tpi]
                                                    Myford uses right hand thread **LINK**
                                                    http://www.myford.co.uk/acatalog/C25.-FEEDSCREW-AND-NUT-FOR-LONG-CROSS-SLIDE—IMPERIAL–30-135-194.html
                                                    Edit: I believe this to be a photo of the existing cross-slide.
                                                    http://www.model-engineer.co.uk/albums/member_photo.asp?a=41596&p=684946
                                                    Edited By Michael Gilligan on 06/08/2016 06:38:15
                                                    #249622
                                                    Roger Head
                                                      @rogerhead16992
                                                      Posted by Michael Gilligan on 06/08/2016 06:32:18:
                                                      Good grief !!! So you 'unwind' the handle to drive the cross-slide in ??? I hate to think of how many screw-ups I would make switching between two lathes with opposite actions. I've had my German-built Ford Focus for 10 years now, and I'm only just beginning to treat the left-side-of-the-steering-column turn indicators instinctively blush.
                                                      Thanks Michael, I learn something new every day.
                                                      Roger
