Screw Thread Measurement Utility
by
The three wire method gives very accurate figures for the truesize of screw threads by measuring from the flanks of the V rather than from the crest of the threads. As the crest are normally truncated, measuring across them gives a false reading. The problem with the three-wire approach is the complex trigniometry involved! This utility saves you all the headaches, allowing you to input just a few parameters and giving a direct readout.
SCREW THREAD UTILITY DOWNLOAD
The zip folder contains three icons: the utility exe file, a desktop icon and a pdf explaining how to use the utility.
Enjoy more Model Engineer Magazine reading.
Click here to subscribe & save.
This utility was written in Visual Basic 5 by Pete Worden.
The utility works with windows operating systems up to W7, though users of later versions may be told a .dll file used by Visual Basic 5 is missing. If you get the error that file Msvbm50.dll is missing, you can download an installer for it from Microsoft here http://support.microsoft.com/kb/180071
Users of Windows 8 may find that with the dll installed the program opens but does not run correctly. We hope to resolve this in the future.
Enjoy more Model Engineer Magazine reading every month. Click here to subscribe.
Article Tags:
About the Author
